FXR adjustable forks?
Old Dec 9, 2012 | 03:36 PM
Agent Clark's Avatar
Agent Clark
6th Gear
Default FXR adjustable forks?
Anybody here switched their FXR forks to use FXDX or XL1200S adjustable forks? Is it worth the swap, or should I stick with originals and re-spring with Gold Valves? Thanks
Old Dec 9, 2012 | 03:41 PM
Gigawitz's Avatar
Gigawitz
Yes, it's worth it, real cartridge forks will spank emulators such as gold valves
Get what you pay for!!
Old Dec 10, 2012 | 05:34 AM
grbrown's Avatar
grbrown
Gold valves are designed to 'emulate' cartridge forks, but as Gigawitz says they ain't no substitute! I had an FXDXT and haven't ridden a Harley with better suspension. I have gold valves in my Sporty and really can't feel any benefit from them, so given your choice I would look for a set of FXDX forks!
The only query I have is are FXR forks the same diameter as FXDX ones? Or would you need to swap the trees as well?
Old Dec 10, 2012 | 07:43 AM
1984_FXRT's Avatar
1984_FXRT
I'll agree that cartridge forks are great - they are a bit pricey. For HDs that aren't ever going to carve corners like a 'Busa - I've found that good, progressive rate springs front/back make a huge difference.
I like the works performance dual-rate progressive fork springs up front, (about $150) and the progressive 412s out back.
Old Dec 10, 2012 | 03:22 PM
Then Came Bronson's Avatar
Then Came Bronson
The later model FXRs (roughly '87-'88 and later) had the same 39mm fork diameter as the FXDX.
The earlier FXRs had the 35mm forks, so you would need to swap out those triple trees.
Old Dec 11, 2012 | 02:29 PM
Agent Clark
6th Gear
Awesome, thanks for the direction, guys. I know everything is lined up for 39mm, need to stick with a 3/4" axle, and keep the same length.
slimm13
Jul 11, 2015 07:40 AM
Shane24
Sep 11, 2013 11:44 AM
KevH
EVO
Aug 3, 2012 10:41 PM
01Sled107
EVO
Dec 24, 2010 09:44 AM
new75
Mar 4, 2010 03:47 PM
