Oil Pressure Switch Help
Old Jan 14, 2013 | 01:51 PM
NC_Grover's Avatar
NC_Grover
Default Oil Pressure Switch Help
I decided to finally replace the oil pressure switch on the glide today. The one i picked up doesn't look like the one thats on it so i looked up the old one on jp cycles and they call it an "oil sender." The oil sender has two wires connected and the oil switch only has one. Is there a seperate oil switch somewhere that i'm not seeing? This is on a 92 electra glide.
Old Jan 14, 2013 | 01:54 PM
soft 02's Avatar
soft 02
The one wire is a body ground type and the two wire probably supplies a ground. Once you find out if its normally open or normally closed you can pick one up at Napa.
Old Jan 14, 2013 | 01:57 PM
NC_Grover's Avatar
NC_Grover
I had already picked up the new switch at the bike shop this morning while getting some other stuff. Question is will this new one work? The one with the two wires seems to not be offered anymore.
Old Jan 14, 2013 | 02:01 PM
soft 02's Avatar
soft 02
Take your old one by Napa. Nothin Harley specific about it I imagine. Ive changed quiet a few.
Old Jan 14, 2013 | 02:03 PM
NC_Grover's Avatar
NC_Grover
Sweet, i'll give that a try. Thanks for the info.
Old Jan 14, 2013 | 02:38 PM
soft 02's Avatar
soft 02
Does it look like this?
https://www.google.com/search?q=2+wi...faJeXfigKShYBg
Old Jan 14, 2013 | 02:44 PM
NC_Grover's Avatar
NC_Grover
Not really. It has bolts on top instead of the slide on things.
Old Jan 14, 2013 | 03:02 PM
soft 02's Avatar
soft 02
Here's a screw type instead of the spayed type.
http://www.ebay.co.uk/itm/1-8-NPT-OI...-/271093748262
http://www.ebay.co.uk/itm/Oil-Pressu...71093748262%26
Old Jan 14, 2013 | 03:10 PM
NC_Grover's Avatar
NC_Grover
Thats what mine is except its chrome.
Old Jan 14, 2013 | 03:33 PM
Doug S's Avatar
Doug S
Just a heads up in case you did not know, they have tapered pipe threads and if you over tighten you run a real risk of cracking the case. I go just a little past hand tight using chanel locks with permatex pipe sealant, make sure there is no oil in the hole and let it sit until the sealant sets..
Ds
