I like the looks of the early Fatboy solid wheels...is there a way to adapt an early set of EVO Fatboy Wheels to my 1987 Electra Glide.? Thanks in advance / Mark
Well, I don't know all the aspects of using a Fatboy wheel on your FL, but I do know that Fatboy wheels were all single disk and don't believe they had the holes to accept a right side rotor. I'm guessing if the axle size and the rotor offset is the same on the wheel you are looking at, it would bolt up, but not as a dual disc set-up.
Up to '92 should go straight in I believe, possibly up to 1999, although the speedo drive was moved to the trans from the front wheel. From 2000 on the wheels were changed from tapered rollers to ball races and the hubs were changed. They have a larger diameter hole in the centre of the rotors and rear pulley, also the big ole rear rotor we have was dropped for a similar style to the front.
With the possibility of up to 1999 opens the door for more wheel options. If Ido locate a later year wheel can i also use the later year rotor or still use my 87 rotor?
I had to replace the rear pulley on my old Heritage and it seemed that the Softails and FLH models were different in every way. I would probably go to the dealership and ask a mechanic there before I spent any money.
