cam bearing puller
Old Jan 24, 2013 | 06:04 PM
RidemyEVO's Avatar
RidemyEVO
Default cam bearing puller
Hi Guys
Was wandering with those of yous that work on sportys as well as the BT evos if the same bearing puller used for an evo cam can be used on an 86 883 for pulling the cam bearings? My son got some andrews cams and wants to do all the cam bearings and I figured I can probably use the tool myself at some time or another so if its the same I will buy it. Also wheres a good place to get one?
Thanks much
Old Jan 24, 2013 | 07:46 PM
Pinetop's Avatar
Pinetop
Default Blind hole puller bearing puller
I went to the local welding and hardware shop and created one from stock on the wall. Oriielly's will rent the item for free. Even if your local parts store does not have it Orielly's personnel said the policy requires them to order one. Good Luck. I am a novice and I did my cam pilot bearing without much trouble.
Pinetop
Old Jan 25, 2013 | 05:54 AM
busterman2's Avatar
busterman2
I recently changed the bearing on my EVO and used a Harbor Freight blind bushing puller to remove and a Harbor Freight bushing/bearing driver to install. I froze the bearing before installing and it went in easy.
Old Jan 25, 2013 | 07:27 AM
RidemyEVO's Avatar
RidemyEVO
I don't mind buying the tool but I'd like to make sure it would work also on an 86 883 for its cam bearings.
mrfikser
Jul 27, 2021 07:56 AM
EarlB
Engine Mechanical Topics
15
Aug 24, 2018 09:10 PM
superderrick
Oct 5, 2014 10:38 AM
pjb
EVO
May 10, 2011 08:25 AM
fj4069
Exhaust System Topics
Feb 12, 2008 09:36 PM
