bad earth?
Old Feb 23, 2013 | 08:59 AM
patcham48's Avatar
patcham48
Default bad earth?
Hi all.
Got aproblem with my right hand indicators. The left ones flash as they should but the right side is very sluggish and slow, although will pick up a bit when you rev the motor. Is this a bad earth somewhere?
Appreciate any help. Thanks
Old Feb 23, 2013 | 09:18 AM
Dr.Hess's Avatar
Dr.Hess
Are the right bulbs the same brightness as the left ones?
Old Feb 23, 2013 | 09:21 AM
patcham48's Avatar
patcham48
They are the same level of brightness, but its like they dont want to flash and when they do is very slow
Old Feb 23, 2013 | 11:56 AM
grbrown's Avatar
grbrown
Try swapping bulbs around, to see if the problem moves with them, as bulbs can develop faults - new ones may solve the problem. If not follow your wires and check them very carefully. It may indeed be an earth/ground problem, or a partial short, due to a trapped or damaged wire.
Old Feb 25, 2013 | 06:07 PM
machinehed's Avatar
machinehed
Sounds like corroded conections again.
Check all connections in the wiring and buld sockets.
Use a paste of water and baking soda to clean the nasties off then flush and let dry.
Old Feb 26, 2013 | 01:50 PM
patcham48's Avatar
patcham48
Thanks for the advice. Much appreciated
TPost
Electrical/Lighting/Alarm
Nov 28, 2016 02:43 PM
LDB187
General Topics/Tech Tips
Apr 11, 2016 05:39 PM
06Cummins
Oct 1, 2013 11:56 AM
Ta2edShady
Jul 3, 2011 07:02 PM
theyammieguy
May 2, 2011 07:41 PM
