Help with Turnsignals
Old Nov 26, 2016 | 05:04 PM
TPost's Avatar
TPost
Default Help with Turnsignals
My bike is a 92 FLHS. I'm having a issue with my Turnsignals. The left side both front and rear flash fine. On the right side when I press the button on my bars the front and rear flash once and stay lit. When I press both buttons they all flash as hazards. I'm guessing it's the flasher module but not 100% sure. Any thoughts. Thanks, Todd
Old Nov 27, 2016 | 08:58 PM
skinman13's Avatar
skinman13
have you done any upgrades, modifications, or replaced anything with the lighting?
Old Nov 28, 2016 | 02:43 PM
grbrown's Avatar
grbrown
Wink
1990 FLHS here, owned from new. Have you tried swapping bulbs around, to see if that changes anything? Bulbs can fail over time and do odd things. You could swap the wiring over, left side to right, to see if the problem changes sides. If so your flasher unit is defective. If not it is more likely there is a minor electrical problem in the right side wiring.
psimpson
Oct 8, 2016 07:08 AM
LDB187
General Topics/Tech Tips
Apr 11, 2016 05:39 PM
patcham48
EVO
Feb 26, 2013 01:50 PM
jgc2521
Apr 1, 2008 01:49 PM
99flstf
Jan 7, 2007 01:42 AM
