Help, Blinker problem.
Old Jan 7, 2007 | 12:06 AM
99flstf's Avatar
99flstf
Default Help, Blinker problem.
I have a 99' Fatboy. Sometimes my left blinker blinks, some times it just stays on w/out blinking. What do I need to replace to fix this? Thanks!
Old Jan 7, 2007 | 12:09 AM
anubisss's Avatar
anubisss
Default RE: Help, Blinker problem.
Check the fuse connections, check the bulbs. You didn't mention if it is front or rear. If it is rear, unscrew the taillight and check the connections. They are inside the taillight. I dunno about the front ones. Get a manual, that would help...Good luck.
Old Jan 7, 2007 | 12:19 AM
99flstf's Avatar
99flstf
I have replaced bulbs. It's the left blinker. When they blink they both blink along with the indicator on the dash. When they don't blink nothing blinks, the lights just stay on. I really don't worry about it much until I come to a 4-way stop and want to turn left.
Old Jan 7, 2007 | 12:23 AM
anubisss's Avatar
anubisss
Sounds like there is a short in the wiring somewhere. I wish I could help more.
Old Jan 7, 2007 | 01:42 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Is that a relay system or electronic? If its a relay system, like the older cars used and all three lights are coming on then its probably the relay itself thats the problem. They use a bi-metalic stripthat heats up under load from the bulbs. If its not heating up enoughit will allow the lights to come on, but not blink.
Ford used to set the circuit loading up so that if one bulb was out the lights would not blink as a warning that there was a problem.
More modern systems often use an electronic switch to do the blinking and its not dependent on amperage loading to activate the blinker. So one or more bulbs could be out and the dash indicator will still blinklike everything is fine and dandy.
TPost
Electrical/Lighting/Alarm
Nov 28, 2016 02:43 PM
LDB187
General Topics/Tech Tips
Apr 11, 2016 05:39 PM
hang3xc
Apr 23, 2014 09:08 AM
trozenhorse
Jun 28, 2010 08:19 AM
83fxrt
Dec 31, 2005 06:13 PM
