Problem with Kury silver bullets.
Old Apr 14, 2011 | 04:53 PM
theyammieguy's Avatar
theyammieguy
Default Problem with Kury silver bullets.
Installed some kury silver bullets up front on my 03 heritage. Now every once and a while the left one will cut in and out. I'm thinking a bad ground but I can wiggle all the wires and it won't duplicate the problem. Anyone else have problems with these lights?
Old Apr 14, 2011 | 07:39 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Sounds like a bad ground as you said. Or maybe a wire that is partially pinched.
Old May 2, 2011 | 04:07 PM
theyammieguy
Well, I checked all my wiring and it's all good. I guess I should of mentioned that I also add kury silver bullet halogens on the rear with a pancea tail light and RTB controller.
I had one load eq installed on the RTB and over the weekend I added another. It cleared up my problem, but now have another. Now the when I hit the left signal, the left will function properly but the right will flash oddly. It doesn't flash with the left one but just random. Same happens when I hit the right turn signal. Do I need to add a diode or two to the fronts? The rears work fine.
Old May 2, 2011 | 07:11 PM
CopperHead2008's Avatar
CopperHead2008
Take the lens cover off and check to see if the bulb unit is still plugged into the circuit board. The circuit board just hangs loose in there. Bad design if you ask me. Mine stopped working all together so I started trouble shooting my splices the harness..etc... come to find out they fell out the plug. Kury should have made the bulb to lock in somehow.
Old May 2, 2011 | 07:41 PM
theyammieguy
Yeah, I already checked that. Im thinking it has something to do with the low draw current the leds use.
LDB187
General Topics/Tech Tips
Apr 11, 2016 05:39 PM
sputnicbmx88
Aug 9, 2013 07:41 PM
coop57
Mar 26, 2009 08:10 AM
ssls6
EVO
Feb 27, 2008 08:45 PM
FLSTSI
May 26, 2005 05:33 PM
