Crankcase vent hole sludge
Old Mar 10, 2013 | 09:35 PM
dz1087's Avatar
dz1087
Default Crankcase vent hole sludge
Decided to re-tighten my crankcase vent banjo bolts that lead to a drain hose setup. When I pulled the front cylinder bolt, there was a LOT of water/oil sludge in both the bolt and the head hole. The rear hole was fine, and I drained a little oil from the engine and no sludge in there.
What could have caused the sludge in that part of the engine and how concerned should I be?
Old Mar 10, 2013 | 09:51 PM
Beemervet's Avatar
Beemervet
Was the bike warmed up first? You may have just had that from condensation. Go for a good ride and try again.
Old Mar 10, 2013 | 09:57 PM
soft 02's Avatar
soft 02
Normal. A little sludge steems off when at riding temp.
Old Mar 11, 2013 | 04:30 AM
Spanners39's Avatar
Spanners39
Its a sign of too many short journeys, give it a long, hard thrashing and it will go away.
Old Mar 11, 2013 | 06:43 AM
grbrown's Avatar
grbrown
In addition to comments above it is also a by-product of additives in the oil you are using. You may find a change to a different brand will either make it worst, or improve it! I had problems many years ago with a popular brand of oil on one of my bikes and a change of brand solved it completely.
Old Mar 11, 2013 | 06:49 PM
dz1087's Avatar
dz1087
Sounds good, fellers. I'm supposed to go on a nice long ride next week so we'll see how she does.
Old Mar 20, 2013 | 10:11 AM
dz1087's Avatar
dz1087
Well, 650 miles complete over two days. Haven't pulled the vent bolt yet to look, but I did have a lot of oil leak out after the final 200 miles. They were pretty fast and a lot of wide open throttle during that last part. I think maybe the.vent bolt on my front cylinder is the culprit in the leak, but exactly how much oil should be coming out of there? I'll post pics in a few, but this seemed like a lot more oil than what I have heard described here. Looking around the bike, that bolt seems to be where most of the oil is pooling, but I'm going to go over it real well and see if it is coming out of anywhere else.
does anyone know off hand how much oil is coming out of the crank vent at around 3k to 4k for extended periods?
Old Mar 21, 2013 | 09:54 PM
98glider's Avatar
98glider
Check oil level maybe overfilled . I always keep the oil a little below the dipstick
Old Mar 22, 2013 | 05:45 PM
machinehed's Avatar
machinehed
Default sludge
Im no expert here as your bike is a different year than mine but i cant remember seeing a crankcase vent hose being installed with a banjo fitting.
They are usually a simple hose and gear clamps as there is very little pressure involved.? I have learned that the Harley motor has a very complicated oiling system but this being said , the crankcase breather hose should either be routed back to the intake or simply dump out to the ground .? Are you sure you are dealing with the correct hoses ?
Rusty Axle
Shovelhead
Mar 22, 2018 07:29 PM
FLTpilot
Engine Mechanical Topics
14
Mar 14, 2017 04:16 PM
NKy Ultra
Jun 9, 2016 08:06 AM
Kenita
Jun 1, 2015 08:37 AM
gant
Apr 9, 2013 10:48 PM
