Won't start after doing top end rebuild
Old Mar 22, 2013 | 01:42 PM
busterman2's Avatar
busterman2
Finally got some time off work to get back on problem. The manifold was out of alignment with carb. Put back together, now it starts good with enricher. When warmed up, I turn off enricher and it sounds real good at idle of 1,000-1,000 rpms and will continue to idle at that speed. When I start to gently twist throttle, it dies instantly. Would mid range circuit be kicking in at 1,100 rpm? The carb sat off bike on workbench for two months while I was doing top end on motor. After the motor was back together and would not run without enricher, I took carb back apart and checked float level. I plan to take carb back apart and soak body overnight in laquer thinner. Low speed screw is 2.5 turns out and float is set by manual, however I will recheck. I will start with air filter off to see if slide is opening when throttle is opened. Any other ideas, I believe it is something real stupid I have done with the carb while apart. Any help appreciated!!
Old Mar 22, 2013 | 02:25 PM
busterman2's Avatar
busterman2
Just looked in manual and I may have jet needle installed on wrong side of the plastic spring seat. Can't check until tomorrow.
Old Mar 22, 2013 | 04:08 PM
Tumper's Avatar
Tumper
The different jet ranges kick in as you twist the throttle, regardless of the rpm. I had this exact issue, and my intermediate jet was the culprit. It was completely clogged, so when it needed to kick in and transition from idle to full throttle it couldn't.
hunter20
May 15, 2016 03:47 AM
imslypig
May 31, 2011 10:52 AM
JohnFlorida
Exhaust System Topics
Apr 26, 2011 02:33 PM
spartan95
Aug 6, 2009 06:14 AM
rivercityslim
EVO
Nov 7, 2007 10:51 AM
