Horn question
Old Dec 6, 2014 | 06:53 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Sounds more like a voltage drop either across the switch or in the wiring to the horn. Most likely in the wiring especially if it's in the head lamp housing and like the other guy who has a problem but not at a higher rpm it's most definitely drop in the wire.
Old Dec 6, 2014 | 07:40 PM
WP50's Avatar
WP50
Originally Posted by Beltdriven
I had the wimpy horn problem.Solved it by using a automotive relay.Tuck the relay and fuse under the seat in a cavity at the battery-Softail in my case.Find the relay wiring diagram on the internet.Your problem will be solved.
What you did was to let the horn switch control the relay rather than causing the switch to carry the load of the horn. The wiring can carry enough current to operate the relay but was marginal to operate the horn.
Good short term fix but you may see problems down road, then again I have seen that fix last a long time too. You can have 12 v at certain point in a circuit but not enough current flow (amps) to operate a given component.
WP
Old Dec 6, 2014 | 08:29 PM
Beltdriven's Avatar
Beltdriven
Default horn relay
Guy's this chicken sheite horn problem is why relay's are used,A relay makes it possible for a accessory such as a horn or a fuel pump to get a full shot of juice from the battery.On the battery power circuit from the relay use the heavy wire and for the ground side go right to the negative terminal of the battery and coat all the connections with a light coating of grease. The Harley horn circuit with the small wiring and the light duty handlebar switch signals the relay.I learned about relays from owning a Porsche 911.Everything is premium on the 911 including every circuit in the car using a relay and heavy gauge automotive wire.
Old Dec 6, 2014 | 08:40 PM
WP50's Avatar
WP50
I'll agree except that to many relays cause their own set problems. Just another set of contacts and connections to become weak and add resistance to a circuit. Have been an auto mechanic (tech as we are called today) for 30 + years and 24 of those at a Cadillac dealer. GM has put out some real junk as have most any auto manufacture has at one time or another including a few Porsche's I have dealt with.
WP
Kacowboy
2014-2024 Touring Models
Apr 12, 2018 08:18 PM
Red 62
Electrical/Lighting/Alarm
Aug 7, 2014 07:56 PM
1harley 1vette
Jan 14, 2014 02:32 PM
TBayKatrina
May 16, 2011 03:20 PM
gas4harley
Mar 26, 2009 10:26 PM
