Drive belts
Old May 2, 2013 | 05:57 PM
brainless fxst's Avatar
brainless fxst
I was looking at the BDL belts . Spanner are the Harley belts carbon fiber ? Or kevlar ? Harley wants $218 bucks for there belt . The bikes an 1988 with the original belt it only has 25000k. Hard launches abuse maybe inproper tention they can only take so much! Thanks for all the input .
Old May 2, 2013 | 06:00 PM
brainless fxst
Originally Posted by Stiggy
97 to 03 = Kevlar, 04 to present = Carbon Fiber. ( Supposedly stronger which is why they're narrower now.) My Kevlar belt (1 1/2") still lasted 119,600 miles.
Now my "stronger" carbon fiber belt and still at 1 1/2" ( wider than any stock belt 04 and later,) should theoretically last until I'm dead (and maybe even longer...)
So if I buy a new belt from harley it will be carbon fiber? Even for an old bike. Mine is 1 1/2. 132
Old May 2, 2013 | 06:02 PM
Stiggy's Avatar
Stiggy
No. Falcon SPC or Gates PolySteel. I got the Falcon through BDL ( I think i was BDL,) on EBay for $177.
Old May 2, 2013 | 08:16 PM
Spanners39's Avatar
Spanners39
You can tell the carbon fibre ones, they don't have grooves on the outer surface.
Old May 2, 2013 | 09:31 PM
brainless fxst
Thanks guys
Old May 3, 2013 | 03:54 AM
grbrown's Avatar
grbrown
To give you an idea of how these things have improved, Harley made a heavyweight version of the original kevlar wide belt for sidecar use. The modern trikes all use the same narrow c/f belt as the other Touring bikes. So if you have a wide belt and can buy a c/f version, that should last into the next century!
Old May 3, 2013 | 09:10 PM
machinehed's Avatar
machinehed
In my opinion only...
There are two major US belt suppliers and they manufacture belts for everyone including heavy industry . I would suggest you stick with these suppliers and steer away from the low priced offshore stuff and all should be good .
An OEM belt should last longer than a motor rebuild if it was trouble free from the outset.
Old May 4, 2013 | 01:03 AM
Stiggy's Avatar
Stiggy
Falcon SPC is made by Goodyear.
PolySteel is made by Gates.
Old May 4, 2013 | 10:46 PM
Spanners39's Avatar
Spanners39
Belt life depends almost entirely on how many stones are on your roads.....especially new tar seal. Check you belt weekly for embedded stones and holes.
NZ roads are a bit rugged and belt failures are very common.
P51Driver
General Topics/Tech Tips
21
Jul 5, 2018 09:23 AM
bg3075
Jun 7, 2015 05:59 AM
Bill Murray
May 2, 2013 12:22 AM
AlCherry
Mar 14, 2009 07:34 AM
Beemervet
EVO
Aug 8, 2007 07:19 PM
