Passing lamps problem
Old Jun 1, 2013 | 01:51 PM
patcham48's Avatar
patcham48
Default Passing lamps problem
Hi all.
Apologies in advance if this problem has been covered. The lamps/bulbs in my passing lights keep blowing, sometimes after a week or so, and some times as soon as they are fitted. Im using the par36 12v sealed units. Id appreciate any advice.
Thanks in advance
Old Jun 1, 2013 | 09:32 PM
miacycles's Avatar
miacycles
Check your grounds and then the other connections. If they are ok then put a volt meter on the battery and see what you have with the engine reved as high voltage will blow bulbs and other things.
John
Old Jun 1, 2013 | 10:59 PM
DarkSideFive's Avatar
DarkSideFive
If your voltage is too high at higer RPMs - you might need to have your regulator replaced.
Old Jun 2, 2013 | 06:18 AM
ironoxide's Avatar
ironoxide
Default agree
I agree with Darkside. Perform the Dr Hess charging system test (sticky above).
Old Jun 2, 2013 | 08:55 AM
patcham48's Avatar
patcham48
Thanks guys, I will carry out the tests you suggested, my regulator is pretty new, I replaced the stator and regulator around 1000 miles ago.
Thanks again
Harbri
Shovelhead
Apr 27, 2013 11:38 AM
davidpisano
Nov 19, 2009 12:56 AM
Spiderxx
Dec 25, 2007 07:03 PM
locutus
Apr 30, 2007 02:02 AM
dan789
Jan 2, 2006 12:04 AM
