slip on exchange
Old Jun 5, 2013 | 07:16 PM
ironoxide's Avatar
ironoxide
Default slip on exchange
Folks, I need your advise. I have a 99' FLSTC with the stock exhaust system installed. If I choose to replace the mufflers (slip-ons), do I need to remove the system all the way to the heads as the service manual suggests? I have a stock set installed with the baffles removed, which I find much to loud. Thanks in advance!!
Old Jun 5, 2013 | 07:43 PM
Spanners39's Avatar
Spanners39
You can fit slip-ons without removing the headers. Sometimes you may need to just loosen the headers to get the brackets lined up.
Old Jun 5, 2013 | 09:52 PM
falconbrother's Avatar
falconbrother
Don't worry about pulling the exhaust on an FLSTC. It's an easy bike to work with. If you have to loosen the exhaust manifold nuts make sure you put a little light oil on them first and let it soak for a little bit. If the exhaust studs back out it's not a crisis but, it's just less work if they don't.
Old Jun 6, 2013 | 08:29 AM
ironoxide's Avatar
ironoxide
That's good news. Thanks again fella's for the advise!
Fblo1690
Apr 24, 2019 12:30 PM
tennheritage
Apr 25, 2015 06:48 PM
jojo2dog
Nov 13, 2012 09:43 PM
Tommygunz13
Apr 8, 2012 08:28 PM
sammer4u
Jul 25, 2011 03:50 PM
