1987 xlh
Old Jun 10, 2013 | 12:00 PM
ashkat's Avatar
ashkat
Default 1987 xlh
seems my 87 stopped pumping oil on me, warmed it up then headin out on the 4 lane for 10 min. the pipes started not sounding right , it was getting hot, no oil light till after i changed the filter, and barely any oil flow, thinking on sumthing plugged or the key broke
Old Jun 10, 2013 | 12:47 PM
Dr.Hess's Avatar
Dr.Hess
Doesn't sound good. Cut the old filter open and look for bits of metal. I think I'd pull the pump off and inspect it as well.
Old Jun 10, 2013 | 12:49 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I remember once someone found that the inside of one of the oil lines had separated and a flap stopped oil flow when the oil was circulating. Kinda like a one way valve.
If you didn't have a problem till you changed the filter I would start there.
Old Jun 10, 2013 | 01:35 PM
grbrown's Avatar
grbrown
If you used an aftermarket oil filter chuck it and get a genuine Harley one. Eliminate that as a possibility.
Old Jun 10, 2013 | 05:58 PM
ashkat's Avatar
ashkat
its possable something got in the tank, had it off a few times looking for a leak that was found on the tank bottom..the filter was from harley, cranked it with no plugs, barely got oil coming out at the sending unit....
guess im on a mission
Bruce Powell
EVO
Oct 7, 2012 09:10 AM
LucyOnBlack
Oct 30, 2011 10:39 AM
martinbastin
Dec 30, 2010 07:09 AM
SemmesSporty
Oct 3, 2007 07:21 PM
winpitt
EVO
Nov 20, 2006 07:18 PM
