replacing lifters
Old Jun 27, 2022 | 07:14 PM
  #61
Abster's Avatar
Abster
Stage II
Default Full synth oil
Originally Posted by Dr.Hess
Evo's make some noise. Some valve noise is just part of the experience. I don't know what yours sounded like so I can't comment on it. I don't know what oil passages might get blocked. The lifter screen is clean, right? And you're not using full synthetic oil are you? Full synthetic in my bike makes it sound like it's coming apart.
Hiya, I am having loud ticking noises also, I have a Mikuni carb, so ticking is standard, but lately, after doing an oil change and switching to full synthetic oil, the ticking is super loud and sounds like it's coming from the area of the cam. Was just about to tear it all apart, but I think after reading your post, I should just drain it and put in the 20W-50 I was running before. Would this gum the engine tho? Mahalo.
Old Jun 27, 2022 | 08:04 PM
  #62
smitty901's Avatar
smitty901
Just a question. have you cleaned the Tappet screen. Something often over looked on the EVO.
Old Jun 28, 2022 | 04:17 AM
  #63
Yankee Dog's Avatar
Yankee Dog
Go back to conventional and see how it sounds. No the synthetic is not "gumming up" anything. As mentioned, check screen. If problem persists after oil change, start thinking other issues like lifters or cam bearing. Try to narrow down the area the sound is coming from. I hope it's as simple as an oil change. YD
Old Jun 28, 2022 | 05:18 AM
  #64
RANGER73's Avatar
RANGER73
A simple rule to follow is
If something is now wrong that wasn’t wrong before it was touched then it’s something you touched last.
Like YD said, put in the 20/50 and see what happens.
Old Jun 28, 2022 | 12:04 PM
  #65
Abster's Avatar
Abster
Stage II
Ah yes! Thank you, that would also maybe tell me if there is any damage to tappets and lifters. I did forget about this and it's so quick and easy to do.
F86
Sep 24, 2017 02:10 PM
brad75raiders
EVO
22
Jan 21, 2017 03:39 PM
Bowhunter61
Sep 21, 2014 01:18 AM
Alamondm
EVO
18
Oct 21, 2013 08:48 PM
1/2crazedbikr
EVO
Aug 31, 2013 07:38 PM
