got everything back together today..Yay! but... I started it up and its sounds like a freaking sewing machine. Like u can hear every valve/lifter in it rattling. Im pretty sure I adjusted the pushrods right. They are 24 tpi , the manual says 2.5 turns and I went alittle closer to 3. You think the lifter are just taking awhile to "pump up"? I only let it run about 3 mins cause of the hell it was raising. May try to readjust just to make sure. Any thoughts?
If your EVO sounds like a pissed off sewing machine then everything is perfect!!!!
Happens to me when I change lifters. It can take several minutes for new lifters to purge themselves of air and pump up with oil. It's a nerve wracking minute or two until that happens.
Sometimes I've had to grit my teeth and ride the bike around the block to get the RPMs and oil pressure up enough to pump the lifters the first time.
Thanks UncleG and EVERYONE else that has guided me through this my first time replacing lifters. I went out and re-adjusted the pushrods to the 2.5 turns the manual says instead of the 3 turns I did the first time. Purring like a kitten!! Its never sounded so good. Lifters was definitely my problem! Id like to thank each and every one that helped me along the way. Ready to put her in the wind!! I just called off work tomorrow so I can ride!! See yall on the back roads!!
I was thinking they just needed to be pumped up. Letting them sit and re-adjusting them may have just accomplished that. Regardless, Good Job. If those were the original lifters, you got your money out of them.
Last question... I cant get the rear tappet block out. Its hitting a fin on the motor before I can get it up far enough to come out. I have used a paper clip to lift the lifters up but didn't help. Any suggestions?
This is odd. I bought new lifter blocks with the intention of replacing mine, and then discovered I couldn't install the new rear lifter block. There's an extra "lump" of material on the side near the case, and I can't fit the lifter block through the hole in the case with the rear cylinder installed. My old tappet block isn't like this. If this is the way H-D is machining their lifter blocks now, I hope I never have to get another new or remanufactured motor, as it's now apparently impossible to remove the rear tappet block without first removing the cylinder.
So, did you ever actually get the lifter block out, or did you have to go in through the gearcase? If you couldn't get the block out, how did you change the rear lifter block gasket?
