Wheel choice help.....
Old Jun 14, 2013 | 10:43 AM
Scootertrash60's Avatar
Scootertrash60
Default Wheel choice help.....
I have a 1985 Low Rider FXSB (stock trees/tubes and swing arm). I am giving it a face lift and I want to go with 16 inch touring wheels front and back. From the research I've done, it appears that I can use wheels from 84-99 models and they will fit. Is this correct?
I am also going to be swapping out the narrow glide front end with a dual disc wide glide set up.
Thanks in advance for the help!
Old Jun 16, 2013 | 02:20 AM
Spanners39's Avatar
Spanners39
Its late and I read the title as "weed choice"...I was gonna say Mexican...but now I have woken up, yes, you can use any wheel that takes taper-roller bearings and they did between the years you indicated :-)
Old Jun 17, 2013 | 11:23 AM
jimbo285's Avatar
jimbo285
Originally Posted by Spanners39
Its late and I read the title as "weed choice"...I was gonna say Mexican... :-)
That's funny right there.
Old Jun 17, 2013 | 08:44 PM
Scootertrash60
Yes that is quite funny!!
Thanks for the info Spanners39. And the laugh!
Old Jun 17, 2013 | 09:43 PM
Tee&Vee's Avatar
Tee&Vee
the domestically grown bud has come a long way in the recent few years especially with the decriminilization in many states. Not that I partake but I have heard from people. The infamous Them...
Old Jun 18, 2013 | 04:39 AM
grbrown's Avatar
grbrown
Back to your question, yes that should work. You want wheels with tapered roller bearings, which on the touring bikes were replaced with ball races around 2000.
Take a close look at this , before you buy anything. The touring bikes use a large thick rear rotor and a bigger caliper than is stock on your bike, which may bolt right up.
harley9701
Wheels/Tires
Feb 20, 2015 09:46 AM
Turret_plug
Jul 21, 2012 05:24 PM
tomzilla
May 12, 2011 12:33 PM
2007fxdc
Jan 20, 2009 10:48 AM
deleontow
Sep 18, 2008 12:11 PM
