Later type wheel change
Old Jun 28, 2013 | 04:24 PM
patcham48's Avatar
patcham48
Default Later type wheel change
Hi all. Ive had a problem with my front wheel for a while now, corrosion on the inner bead, so air escapes from the tyre. I have a 1995 Road king. My question is, If I put a later front wheel on, after changing the bearing to a 3/4" will; the wheel fit on using the same spacers? Hopefully there is a photo of the wheel I will be going for.
Thanks
Old Jun 29, 2013 | 10:30 AM
grbrown's Avatar
grbrown
I have used a rear one of those, in a 2007 swingarm on my 1990 Glide. The bearing housings are larger in diameter, so your current brake discs won't fit that wheel. The front fork spacing on the Glides hasn't changed since Adam was a boy, so there is a reasonable chance it will fit your forks with your spacers.
Old Jun 29, 2013 | 11:16 AM
Jake911's Avatar
Jake911
If your going from the timkins to sealed bearings you'll need new axle spacers. No way to know what size. You'll just have to put on the wheel, center the wheel, line up the rotor, and measure. And what grbrown said about the rotor.
Old Jun 29, 2013 | 12:26 PM
patcham48's Avatar
patcham48
Ok thanks for the info, must admit I hadn't thought about the brake discs being different, and I thought I may need new spacers as mine are recessed in to the bearings and I think the later ones are flush fitting.
Thanks again for your info.
Cheers
Old Jul 2, 2013 | 09:31 PM
95BadBoy's Avatar
95BadBoy
Default fix
Just take a wire brush on a drill and clean off the corrosion then get some bead sealer
put it on the wheel then install tire. FIXED >>> mine has not leaked since.
Wisco1200
Wheels/Tires
Sep 25, 2016 03:43 PM
Quater5k
Sep 18, 2016 06:37 PM
Curtis36j
May 3, 2016 04:10 AM
T-rat
Jan 27, 2013 04:53 PM
Madjew
EVO
Jul 29, 2012 09:18 PM
