front wheel question
Old Jan 27, 2013 | 04:22 PM
T-rat's Avatar
T-rat
Default front wheel question
I am looking to go to a 21" laced front wheel on my 2000 1200 with a mag wheel. I have found an 09 front wheel in like new condition but I have been told that the front wheel bearing is different size. I have also been told that I can put the older part number bearing in the late model hub and it will work. I have also been told that this won't work. Does anyone know for sure? I can get this wheel at a really good price so I would like to know. Any help from some one who knows is appreciated!
Old Jan 27, 2013 | 04:29 PM
Hogpro's Avatar
Hogpro
Former Sponsor
You can put 3/4" bearings in the newer wheel but it is unlikely the current axle spacers you have will line properly once this is done as the width of the bearings is different. I am sure you can find spacers the right size but that is the part of this conversion that complicates matters.
Old Jan 27, 2013 | 04:48 PM
T-rat's Avatar
T-rat
having to change the spacers I can do but what about the brake rotor will it still be in the right location for the caliper or will I have to space it as well. It seems to me it should be right and the spacers on the right side would have to be changed. Am I thinking right?
Old Jan 27, 2013 | 04:53 PM
Hogpro's Avatar
Hogpro
Former Sponsor
If the rotor is off a little you can alwyas shim the caliper out. Assuming both of the Sportsters have a narrow glide front end you should be fine. However it depends on the bike the 09 wheel comes off.
jqb12
Wheels/Tires
Mar 28, 2017 04:42 PM
Curtis36j
May 3, 2016 04:10 AM
patcham48
EVO
Jul 2, 2013 09:31 PM
POPZ J THE FLORIDA KRACKER
May 5, 2011 01:03 PM
thomasf59
Oct 4, 2007 08:27 PM
