Carb removal
Old Aug 1, 2013 | 06:49 PM
gump305's Avatar
gump305
Default Carb removal
Well this is a noob question, but can you remove the carb without taking the tanks off? I was reading the service manual for my 97 heritage and it said to remove the tanks to get the carb off. I watched some videos on youtube and they were able to get the carb off without taking the tanks off.
Thanks for any tips you guys may have.
Old Aug 1, 2013 | 07:18 PM
Beemervet's Avatar
Beemervet
Yes, you can remove the carby (hello Spanners) without removing the tank.
Old Aug 1, 2013 | 07:36 PM
Spanners39's Avatar
Spanners39
...you'll be saying "Arvo" instead of afternoon next.....
Old Aug 2, 2013 | 12:12 AM
Slammed-N-Senseless's Avatar
Slammed-N-Senseless
Yes, you can, and I have done that route in a moment of lazines. Big mistake, HUGE, everything about the job was way more difficult with the tanks left on. I'll never do that again!
Old Aug 2, 2013 | 12:35 AM
Scratt's Avatar
Scratt
As said yes you can, but what makes it a pain is the throttle cables are wire tied to the frame so you don't have a lot of room to undo the cables and you could possibly scratch the tank. If you leave the tank on make sure you loosen the cables all the way before you pull the carb. I don't know how long the carb has been on, but if the carb is hard to pull out of the intake then replace the gasket on the intake that the carb slides into.
Old Aug 2, 2013 | 03:42 AM
citytrucker26's Avatar
citytrucker26
And when putting the carb back on, be sure to use dish soap and water on the rubber gasket to make sure it has a good seal. Should always do that when changing rubber gaskets. A friend at a shop aided me in this advice when I was rebuilding the carb on our old sportser.
Its a old trucker trick too. If a glad hand is leaking, just put some windex, or even spit on it and it makes the rubber stick together. Stops the air leak.
Trucker Gary
Old Aug 2, 2013 | 08:21 AM
miacycles's Avatar
miacycles
If you don't want to remove the tanks you may be able to unbolt the back and block it up and gain some working room. Hope this helps.
John
Old Aug 2, 2013 | 10:48 AM
gump305's Avatar
gump305
Thanks guys, that's the info I was looking for. I might as well take off the tanks to clean them and check everything over.
Old Aug 2, 2013 | 11:23 AM
Ken Oaff's Avatar
Ken Oaff
fit a decent quick disconnect fuel line fitting to the balance tube, it makes live a bit easier and less messy
Old Aug 2, 2013 | 05:25 PM
bluharley's Avatar
bluharley
I love the pic....just warms my soul.
Cypunk
Apr 21, 2015 01:59 PM
tinnermanmark
General Topics/Tech Tips
18
Mar 15, 2014 11:48 AM
NickD
Exhaust System Topics
Jan 22, 2011 07:43 AM
Ultra 99
Apr 18, 2008 09:02 PM
cHarley
Feb 24, 2007 10:55 PM
