Rebuilding a CV Carb Question ???
Old Jan 21, 2011 | 12:06 PM
NickD's Avatar
NickD
Default Rebuilding a CV Carb Question ???
I have a Mikuni carburetor on my bike, but I'm rebuilding a CV carb (#27414-99) for a friend and I'm not all that familiar with it. I'm at the point where I want to run the carb body through the parts washer tank (filled with Gunk Carb Cleaner) but I'm worried about the two inlets (shown pictured.) I think they are aluminum but I'm not sure if they aren't plastic coated, or just painted black. Are these inlets threaded on the carb? I gently tried turning them off but I'm afraid to go at them too hard if they are fixed in place and I break one. Anyone know how to remove them? Do I have to remove them? My main concern is the solvent will hurt whatever it is they are coated with.
Old Jan 21, 2011 | 01:28 PM
djl's Avatar
djl
The fittings are brass/plastic and are pressed into the carb body. You have to destroy them to remove them; there are brass replacements. The carb doesn't look that dirty; don't think it is necessary to run it through the cleaner. A little fuel and some compressed air is all you need. Don't know if you are aware that the float adjustment for a CV carb is a little different from most float adjustments. It it's not right, fuel mileag will be affected. Find a service manual for the bike/carb and check out the float level adjustment procedure.
Old Jan 21, 2011 | 05:22 PM
Oldfart666's Avatar
Oldfart666
I have worked on many Mik's and have found the only solvent that affects those spigots would be lacquer thinners.Watch when you use air pressure in the mixture srews,some models have a small washer and O-ring in the passage.
Old Jan 22, 2011 | 07:43 AM
NickD's Avatar
NickD
Thanks, and just for future reference the Gunk Carb solvent didn't bother the plastic coated nipples. And yes, I found the small washer and replaced that o-ring on the mixture screw with a new one.
Bagged, tagged and ready for return for service!
supermanotorious
Mar 25, 2018 09:36 AM
tinnermanmark
General Topics/Tech Tips
18
Mar 15, 2014 11:48 AM
badazdvette
Carburetor Related
Apr 4, 2013 05:44 PM
RidemyEVO
EVO
13
Jan 12, 2011 07:47 PM
jhowle9475
Aug 30, 2010 05:37 AM
