Front end wobble…normal?
Old Aug 12, 2013 | 09:02 AM
McMurphy's Avatar
McMurphy
Usually when Im slowing down....Im pulling the clutch to downshift....and using the front brake.....kinda hard to do with no hands.
Old Aug 12, 2013 | 10:18 AM
MJHJEA's Avatar
MJHJEA
Nowhere in the manual does it say butt for seat...hands for handlebars?? Maybe they hit on it in the rider's edge "advanced" course. lol Coasting and downshifting appropriately only requires a split second of left hand/left foot usage....no brakes needed....not that difficult really. Gives you a chance to shake out your hands or whatever. Not in traffic areas of course, I do have a little sense left.
Old Aug 12, 2013 | 10:40 AM
beakerztoyz's Avatar
beakerztoyz
MJ you do realize your front brake is responsible for a way greater portion of your stopping power than the back brake right??? As another poster said though there is a way to check and see if the front end is too loose any good indy would be able to check the fall away for you if you dont know how.
Old Aug 12, 2013 | 01:17 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If you say so !!!!!!!!!!!!
Old Aug 12, 2013 | 06:22 PM
MJHJEA's Avatar
MJHJEA
Front brake more stopping power?..thought I was in the general HD chat section for a moment. Grasped that concept somewhere back around 1984-85. But yes, thanks, I am trying to educate myself on how to check out the front end as you mention.
Old Aug 12, 2013 | 10:23 PM
beakerztoyz
If you have a factory manual it should be in there, it involves hanging a plumbob from the front fender and measuring the distance you can turn the front end before it actually moves the rest of the way on it's own from what i gather. Basically your measuring just how tight the bearings in the steering neck are. { I think} Like I said any shop that works on harley's will be able to do it and I am sure a lot of guys around here could explain it better than me
good luck !
Old Aug 12, 2013 | 10:53 PM
cowboy 51's Avatar
cowboy 51
it's your ride , ride it your way , If you have a floor jack aka bike jack & a friend to help slowy lift bike & you or friend look at the frond end & rest a hand on front fender , you can see & feel a slight movement back word , if you see or feel it double check neck bearings for were or lack of lube
Old Aug 13, 2013 | 02:33 PM
MJHJEA's Avatar
MJHJEA
Cool, thanks guys
Old Aug 18, 2013 | 07:23 AM
traildog's Avatar
traildog
HEY! Glad i found this thread. I was coming to a stop (coasting) yesterday, and I took my hand off of the clutch side, and the bars started wobbling. Put hand back, and it stopped immediately.
When she's on the jack, the steering falls from side to side VERY easily..
Something seems a bit loose to me. I'll put her up later and check.
Old Aug 20, 2013 | 06:25 AM
MJHJEA's Avatar
MJHJEA
TrailDog, let me (us) know what your findings are. I have not investigated mine as my time has been limited and the wobble is fairly minor.
