Front end wobble…normal?
Old Aug 20, 2013 | 06:56 AM
traildog's Avatar
traildog
Originally Posted by MJHJEA
TrailDog, let me (us) know what your findings are. I have not investigated mine as my time has been limited and the wobble is fairly minor.
Will do. I'll be digging into it as soon as the rain hits......
Old Aug 20, 2013 | 08:15 PM
ironoxide's Avatar
ironoxide
Ok guys, here's where you realize that I really am an idiot. I have always had a bad habit of taking my hands off the handlebars when I decelerate and downshift to a stop ( not always but a lot). I've noticed that if I haven't downshifted to the corresponding lower speed, the bars will start to wobble to and fro. But when I then kick her down to the appropriate gear, she's fine. Was wondering if that would be normal or if it sounds like my fork neck bearing is going bad? Shortly after I bought my 06, I was pulling this stunt and it darn near threw me off the bike. This is nowhere near that bad, but I'm wondering if it could be same issue….same front end components in my 95? I would have to think some of you do the same thing when slowing down, or should I not even ask??
All of my bikes tended to do that. From Honda's to Harleys...for about 20 years. I just don't worry about it anymore. Otherwise, they've all run perfectly fine.
Old Aug 21, 2013 | 01:08 PM
jimbo285's Avatar
jimbo285
Mine (93 Heritage, Fatboy, Deluxe) wobbles when decelerating if I take a hand off. Soon as I slightly touch the bar, it stops wobbling. I mean I barely put my clutch hand back on and she straightens right out. Wierd... And btw, what is the proper tire pressures for our Softails?
Old Aug 21, 2013 | 03:05 PM
ironoxide's Avatar
ironoxide
36psi front 40 psi back. However, I run a bit higher in both, suit to taste.
Old Aug 21, 2013 | 03:18 PM
traildog's Avatar
traildog
That's EXACTLY what mine does. Keep both hands on the bars, no wobble......
Old Aug 22, 2013 | 10:45 AM
MJHJEA's Avatar
MJHJEA
Manual shows for Heritage, Dunlops only..... 36psi front/36psi rear solo rider......36psi front/ 40psi rear solo rider and passenger. Wobble has gotten no worse in the last 2000 miles or so. I might not worry about it unless it does.
1BMFFL
Jun 19, 2016 12:40 PM
Zanejjnelson1
Nov 10, 2014 11:22 AM
Time2Cruise
Sep 27, 2010 12:24 PM
TAWoody
Jul 21, 2010 08:47 PM
yomomma22
Oct 5, 2007 12:07 PM
