Need a little advice...i picked up a 2008 SuckerPunch Sally bobber...bike came with a 80" Evo motor. My other bike is a 2007 Road King with a Rev Perf 107", Woods 777 cams, Barnett clutch, SE pushrods, Thundermax etc. I would like to hotrod this bobber out as well. I'm just not as familiar since this is my first Evo I owned.
I'll do alot of bar hopping on this bike but i recently just did a few 200+ mile days as well. Any recommendations on cams for the 80" Evo. I did a search but a lot of the talk was for bigger bikes. keep in mind, this bike is small and light as hell. thanks.
A lot of the smaller distro bikes may have "punched" out engines already. A lot of guys in this forum, best on earth, hate to admit how much faster a Twinkie is than an Evo.
I would sincerely doubt you have a moco crate engine in yer frame. You could call SPS and maybe Ami will answer if he ain't too busy tattooing somebody's ***.
For a stck 80" EVo I like the SE-11 cam with 10.5:1 pistons
ScrEamIn’ EaglE
Ž Pro EVoluTIonŽ
1340 camShaFTS
Fits ’84-’99 carbureted evolution 1340-equipped models.
Some cams may also be used on eFI evolution 1340-equipped
models in conjunction with an approved eCM calibration. See
your Dealer for details.
SE-3 cam
Bolt-in cam for heavy bikes that comes in the Screamin’
eagle
Ž eFI Stage II kits. Strong low- and midrange torque that
works best from 3000-5000 rPM. Street-legal in Stage II
evolution eFI kits only. For race application only.
25422-97 $199.95
SE-4 cam
unique advanced profile design provides exceptional bolt-in
power for heavy bikes. Broad torque band from 3000-5500
rPM.
25752-97 $199.95
SE-11 cam
This is the next generation Se-1 bolt-in cam for lighter bikes.
Advanced profile design creates power from 3500-6000
rPM. This is an awesome horsepower cam in a bolt-in
disguise. unless specified, not for use on eFI models.
For
25753-97 $199.95
SE-57 cam*
Outstanding cam utilizing an advanced profile design. When
combined with Screamin’ eagle carb/intake/air cleaner/
mufflers/high-compression pistons and Screamin’ eagle
heads, this cam produces a broad torque curve from 3000-
5500 rPM with a peak horsepower of an astounding 95 at
6200 rPM. This cam requires compression increases for
optimum performance.
25754-97 $199.95
nOTe: 1340 Cams over .510" lift may require case and/or tappet guide machining for cam lobe clearance.
’84-’85 model’s pistons may need to be fly-cut to obtain proper clearance. Please refer to instruction sheets
and service manuals for more detail.
ScrEamIn
ScrEamIn’ EaglE Pro EVoluTIon 1340 camShaFT SPEcS
TDC
Part Lift @ Valve Duration @.053 Timing @.053 Lift @ Valve
Description Number Intake/Exhaust Intake/Exhaust Lift Open/Close Intake/Exhaust
