EV27 cam and..........?
Doing an Andrews EV27 cam, can I leave the stock A/C & filter, and the stock slip ons, can I maybe just drill out or alter the baffles? Does anyone know the part # for SE II slip ons from back in the day, maybe find a set on E-Bay?
Thanks.
Thanks.
You don't have to mess with the slip-ons if you don't want to.
Bolt-in cam for light bikes (FXRS, etc.) adds significant mid-range power without affecting idle
A 6,000+ rpm cam for stock heads and springs with hydraulic lifters
EV5 GRIND CAM
Designed for mildly stroked motors or motors with head work done
Works with stock hydraulics, with stock spring travel set to .560" minimum
Excellent power in the 2,500-6,500 rpm range
EV7 GRIND CAM
Designed for big-inch stroker motors with head work
Excellent in the 2,800-6,500 rpm range
EV13 GRIND CAM
Bolt-in cam for street or touring use with more mid-range and upper-end power than the stock 88 EV cams
Especially effective in reducing oil temperature
Uses stock springs
EV23 GRIND CAM
Bolt-in cam for heavier touring bikes and high-geared bikes with 65-tooth rear pulleys
Crisp throttle response and strong pulling power from 1,500 to 6,000 rpm
Works well in higher altitudes
EV27 GRIND CAM
Bolt-in street cam with fast open and close ramps
Similar timing to EV3, but designed to produce a very broad torque band
Pulls from 1,500 to 6,000 rpm
EV38 GRIND CAM
Lower lift exhaust for easy installation
Bolt-in for lighter bikes (FXLR, etc.)
Great mid-range and high-end power
Longer exhaust cam lowers oil temperature
DEV46 GRIND CAM
Bolt-in performance cam with fast open and close ramps
Similar to EV3 but higher static compression pressure for 4,000+ rpm with stock heads and hydraulic lifters
EV51 GRIND CAM
Long duration for modified street motors
Easy installation
Power range from 3,000-6,500 rpm
EV59 GRIND CAM
Designed for modified 80" to 88" motors
For use with high lift springs and collars
Very broad powerband to 6,000 rpm
EV72 GRIND CAM
Upgraded EV7, for 92" or larger street motors
For use with Andrews springs and titanium collars
Very broad powerband, 2,800-6,000 rpm
OK for use with hydraulic lifters
