Too much oil
Old Sep 3, 2013 | 08:57 PM
RidemyEVO's Avatar
RidemyEVO
Default Too much oil
Wife's bike an 89 heritage decided it was going to do some seeping out the derby sitting on the kickstand. When we got home I pulled the derby and new before I pulled the last bolt that I would need the drip pan. Pulled the cover and sure enough too much oil.
So my thoughts, last time I changed the primary I had remembered reading somewhere or in the manual that the heritage unlike the same year flhtp takes more oil. In my flhtp I normally just dump in a litre of ATF and with her heritage I think I used like 1.5 liters or something like that ,found it in the manual and pretty sure I would have done it with bike on jack straight up.
Question is what is the recommended oil capacity in the primary for the 89 heritage ?
My next question is if the crank seal is leaking into the primary is it a safe repair doing it from in the primary with the inerds removed or should I say can it be repaired from in the primary?
Thanks
Old Sep 3, 2013 | 09:30 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Thanks
I don't know about the '89 but mine I just fill to the bottom of the clutch hub.
I have no idea what you are trying to ask with the second question.
Old Sep 3, 2013 | 09:39 PM
RidemyEVO's Avatar
RidemyEVO
Tex did I do that bad? Basically I've heard of instances where the primary side crank seal starts leaking into the primary, increasing the amount of oil in primary and decreasing oil in the oil bag. If this is the case can the seal be replaced from in the primary?
Old Sep 3, 2013 | 09:40 PM
Tee&Vee's Avatar
Tee&Vee
This is how I did mine, a,1998 Fltr
Remove primary
Remove chain tensioner
Remove stator nut, 1-1/2" torqued to ~170lbs
Remove chain
Remove stator stuff
Remove 12026b, inspect the perfectly good part and replace it anyway. Then wonder...
Properly seat the new seal.
Hit rewind.
Old Sep 3, 2013 | 09:45 PM
bluharley's Avatar
bluharley
My '88 FLT fills to the bottom of the inspection cover, not the derby cover. I think all the evos were the same. In 1990 they changed the fill to the bottom of the clutch basket. Someone correct me if the Heritage is different.
As for the seal, yes you change it from the primary, you have to pull the guts out, compensator, clutch hub, primary chain, rotor, and the seal. Change the spacer too.
Old Sep 3, 2013 | 09:46 PM
texashillcountry
Dirt don't hurt
To be honest I don't know for sure but I think you can.
Old Sep 3, 2013 | 10:00 PM
RidemyEVO's Avatar
RidemyEVO
I topped up the oil bag and removed some oil from the primary so I know where it is with bag on side stand, I'll get her out for a few good rides and check it again.
Old Sep 3, 2013 | 10:02 PM
1997bagger's Avatar
1997bagger
Crank seal lip is set up to seal the primary oil from entering the engine, the engine is dry sump and holds no oil in the case unless you have the oil bag draining into the engine case by the famous oil pump check ball. See if you are loosing some engine oil while setting.
Yes, you can change the seal behind the compensator and probaly needs replaced but think you have 2 problems, hardened crank seal and oil pump check ball seaping - just a thought
Old Sep 3, 2013 | 10:22 PM
RidemyEVO's Avatar
RidemyEVO
The bike had been sitting for a few days. I will check the levels again by the end of the week. I've often found when my bike sat it would get a load of oil in the bottom end but for the most part would puke out the breather but her breather is dry. The primary oil didn't really look darker than the normal dark red, good chance I put too much when it was straight up.
Old Sep 4, 2013 | 10:44 AM
marktruckee's Avatar
marktruckee
Replacing the seal/spacer is relatively easy, once you get all the parts out of the way. To install new part, you can use the comp. sprocket nut and a piece of PVC (I think I cut mine around 2 inches) to press the seal and spacer into place, as one unit. I greased up the lip of the seal to avoid any initial burn into the spacer (I am probably overly cautious).
When you bolt the stator back into place, I sealed up the screw holes on the stator and stator clip. I was told on this forum that the holes go through the engine cases and can allow engine oil to seep into primary if not sealed. A tube of ATV should fix you up.
