30t pulley what belt?
Old Sep 5, 2013 | 07:29 PM
ramdaspadhye's Avatar
ramdaspadhye
Default 30t pulley what belt?
1998 Electra, 6 speed revtech
139t belt have enough adjustability or 135?
Old Sep 5, 2013 | 10:32 PM
Spanners39's Avatar
Spanners39
Depends, what rear pulley you have and how many teeth you had on the front pulley before.
Old Sep 6, 2013 | 12:23 AM
ramdaspadhye
Stock rear idk how many tooth, front stock is 32
Old Sep 6, 2013 | 12:28 AM
Beemervet's Avatar
Beemervet
Stock rear should be 70T.......
Old Sep 6, 2013 | 03:57 AM
Spanners39's Avatar
Spanners39
You are on the cusp of one being too long and the other too tight. I would adjust the rear wheel fully forwards and then measure what length belt you need and compare with specs...unless someone on here knows for sure and can assist.
Old Sep 6, 2013 | 05:26 AM
ramdaspadhye
Yeah I was hoping someone had done this swap before. I may just go with a 31 and run stock length belt
Old Sep 6, 2013 | 07:56 PM
1997bagger's Avatar
1997bagger
Put a new stock belt on it and will be ok with a 30/70 set up, you will have enough room for adjustment. I took a carbide deburr bit and added clearance for several future adjustments but a stock belt will work the way it is.
When clearanced, it will go back as far as axle flange hitting the shock mount and I actually got mine too tight after 4 years on the belt with a recent adjustment, had to back it off a little. Also used a HD sidecar belt that is one tough unit and doesn't stretch
deadhawg
Aug 20, 2023 07:07 PM
128auto
May 7, 2013 11:15 PM
superstandardFL
Apr 3, 2013 02:26 PM
Maddogs700srx
Jun 26, 2008 08:22 AM
drod
Sep 16, 2006 04:35 PM
