Lessons from a high mileage Harley
Old Sep 10, 2013 | 10:35 AM
Dr.Hess's Avatar
Dr.Hess
I've lost a couple of motors running Castrol GTX. Maybe it was oil related, may be it wasn't. Probably wasn't in at least one, but to me, that stuff is bad luck and I don't run it anymore in anything.
The thing that kills stators is an intermittent short, in my experience.
Old Sep 10, 2013 | 11:31 AM
falconbrother's Avatar
falconbrother
David Willett:
http://www.ibmc.org/spotlight.asp
Old Sep 10, 2013 | 03:09 PM
Spanners39's Avatar
Spanners39
What kills stators from my observations is the insulation breaking down in the rubber block that goes behind the stator and into the crankcases.
Because its a permanent magnet rotor, the stator is always working, the regulator bleeds off the unwanted voltage (when the battery is fully charged) as heat, so I don't really think its caused by the battery.
Old Sep 10, 2013 | 05:57 PM
Uncle G.'s Avatar
Uncle G.
I think it's poor connections between the stator and the voltage regulator that kills the stator. With a poor connection, you're not maintaining good contact between the stator and the voltage regulator, so the regulator can't do its job. How many of you ever check the condition of the connector?
Old Sep 10, 2013 | 07:38 PM
checkers's Avatar
checkers
Originally Posted by cowboy 51
heck I've been useing fram filters for many years on every thing I own with a engine & never had any trouble from them , as for high mile bike way to go on them both , shows ya a good PM GOES a long way
Do yourself a favor: Spend $5 on a "fullsize" Fram standard filter, cut it open and look at what's inside, you wont use another one. I speak from experience of doing this with 6 automotive filters for a demonstration and comparison of these brands, Fram, Motorcraft, Mopar, AC Delco, Wix, and a Mopar, again you will not use a Fram. Cardboard ends, glued to a small amount of filter paper and no by pass or anti backflow control on several of their filters. Sorry for the highjack.
Old Sep 10, 2013 | 09:50 PM
Broncobilly72's Avatar
Broncobilly72
I have heard others' complain about Fram filters on the HAMB (a hot rod/custom forum). They use to be good filters, but like alot of things these days - no more. I think Wix are one of the best filters out there. I believe that NAPA Gold filters are made by Wix?
Old Sep 11, 2013 | 04:00 AM
gamble71's Avatar
gamble71
wasn't gonna weigh in, but I'll just throw this out there. Castrol went to court and had the definition of synthetic changed so that they could sell Dino oil as Synthetic. they do make a true synthetic, but just like Mobil/Amsoil you're gonna pay for it. I refuse to use their products due to deceptive advertising.
Old Sep 11, 2013 | 04:55 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by machinehed
Checked some aircraft aircooled motor sites a while back to see what type of oil filter THEY use .
SURPRISE ... they dont use oil filters !!!
Apperantly the aviation industry adhears to a policy of regular oil changes after so many hrs. of engine operation including a spectoral anaysis of the oil to verify engine condition .
I could be wrong here but i was very surprised to see this at the time.
I have been a licensed Airframe and Powerplant mechanic for over 30 years, take it from me: air cooled aircraft engines use oil filters .
Old Sep 11, 2013 | 08:15 AM
Dr.Hess's Avatar
Dr.Hess
I run Genuine Toyota filters on my bikes.
Old Sep 11, 2013 | 01:06 PM
carlgrover's Avatar
carlgrover
There's pics of just that floating around the internet somewhere. Guy did a comparison of a bunch of MC filters. Said Fram was a nightmare. Might have been you that did it, I don't know.
Anyway, I would be terrified to run a Fram after seeing those pics. I would rather run without a filter at all.
Carl
