'95 FXSTSB Re-Ignition Issue
Old Sep 20, 2013 | 08:55 AM
96black&blue's Avatar
96black&blue
I agree with fuel air mixture theory
Old Sep 20, 2013 | 03:10 PM
Trmeans87's Avatar
Trmeans87
I had the same symptoms with my 99 nightrain. The fix was replacing a torn diaphragm on the bottom side of the carb. It was hard to start and keep running for the first 5 min and I would always have to use the choke.
Old Sep 20, 2013 | 11:47 PM
Kushman's Avatar
Kushman
With a 48 slow I cannot see you running lean with only those mods. How many turns of the screw did you go, I run a 44 slow and am just a tad over 2 1/2 turns on the screw. I would first look for an intake leak then as cowboy mentioned the float level. I would also check the petcock and fuel line for restrictions while I was at it.
Old Sep 21, 2013 | 12:25 AM
cowboy 51's Avatar
cowboy 51
I went back & re read your first post a 44 might be a better slow jet to start with , also try looking up www.CVperformance .com that's all they do is CV carbs , no matter what year it is & all his parts are made here in the states nor jap crap like Hd will sell you
Vmann
EVO
17
May 29, 2017 06:00 PM
underdog601
Sep 19, 2013 09:04 PM
r evolotion
EVO
15
May 21, 2013 04:19 PM
Lord_Rahl
Dec 21, 2009 02:08 AM
JBaker421
Exhaust System Topics
Nov 19, 2009 06:31 PM
