Springer front end clunking noise
Old Oct 2, 2013 | 02:17 PM
DCRANER's Avatar
DCRANER
Default Springer front end clunking noise
My 92 FXSTS has 15,000 miles, as I hit a bump I get a clunking noise, seems from the front end.
Thoughts?
Old Oct 2, 2013 | 02:27 PM
Dr.Hess's Avatar
Dr.Hess
Bushings, neck bearings, wheel bearings?
Old Oct 2, 2013 | 02:53 PM
big cahuna's Avatar
big cahuna
No grease where there should be.,,
Old Oct 2, 2013 | 03:02 PM
Dr.Hess's Avatar
Dr.Hess
Oh, also, I talked to a springer guy once at Sturgis and he said he had a lot of problems with the headlight housing getting loose, so you might check that too. I think he was on his 3rd or 4th headlight housing.
Old Oct 2, 2013 | 03:50 PM
Spanners39's Avatar
Spanners39
Shock absorber bushes? There are a lot of things on a Springer that can make a noise...
Old Oct 2, 2013 | 05:28 PM
Doug S's Avatar
Doug S
Shock bushes, Headlight isolators, neck bearings... There is a series of adjustments one should make every 20K on a springer and it's not something you want to ignor... They are in the book...
Ds
Old Oct 2, 2013 | 08:48 PM
traildog's Avatar
traildog
OK, is a "bush" a "bushing?"
Old Oct 2, 2013 | 09:07 PM
Spanners39's Avatar
Spanners39
Yes............
Old Oct 3, 2013 | 06:05 AM
DCRANER's Avatar
DCRANER
Ds
Neck bearing checked as I just had a full service @ 15k miles. My headlight stopped working the other day, found the inside 3 prong fitting fell off the light connection. Fixed that but realized there is a lot of buzzing / vibration on the old Springers. I will have to check the bushing next.
Thanks all for the suggestions.
Old Oct 3, 2013 | 07:30 AM
Rob85WG's Avatar
Rob85WG
A bush is something different over here. If you don't lube it, and ride it hard, you can wear it out. If that happens you can have the bush tightened but it is better to upgrade the whole machine to a later model.
Can you tell I've been furloughed and have nothing better to due? I better go get the wash done before the boss gets home.
