valve float
Old Oct 7, 2013 | 08:50 PM
beakerztoyz's Avatar
beakerztoyz
I used the Wikipedia reference and just because it's on Wikipedia doesn't make it wrong ... Valve Float, Valve Loft and Valve Bounce .... Three Different Scenarios!
Valve Float is an adverse condition which occurs when the poppet valves on an internal combustion engine valvetrain do not remain in contact with the camshaft lobe during the valve closure phase of the cam lobe profile. This reduces engine efficiency and performance and potentially increases engine emissions.
Valve Loft is intentionally using a controlled valve float to increase lift and duration of the valve open cycle. In some motorsports there are rules that limit camshaft lift; therefore, provoking this type of exploitation. Properly optimizing the system avoids undue stresses to the camshaft lobes and tappets.
Valve Bounce is a related condition where the valve does not stay seated, due to the combined effects of the valve's inertia and resonance of metallic valve springs that reduce the closing force, and allow the valve to re-open partially.
Right... well I don't know too much about the Harley's valve train.... although I have been told it is basically the same type of setup as a smallblock chevy's which I'm fairly familiar with after reading through these wikipedia things I pity anyone who has to try and figure out just how in the blue hell to fix the valve train problem from this.
To the best of my knowledge the cam doesn't touch the valve directly.... and ya floating valves are caused by the hydraullic lifters and or weak valve springs at high rpm's and no matter what causes it it aint good for the engine. I believe most evo's have factory rev limiters that will kick in b4 valve float
pest889
Engine Mechanical Topics
Sep 15, 2014 03:06 PM
jrscars
EVO
Jul 19, 2013 09:58 PM
ladman0311
EVO
21
Jul 12, 2011 10:08 AM
Anthonyamastr52
EVO
Apr 19, 2009 03:20 PM
Fritzwm
Oil Archive (no new posts)
Apr 13, 2008 07:33 PM
