Transmission question
Old Oct 6, 2013 | 04:57 PM
traildog's Avatar
traildog
Originally Posted by texashillcountry
The reason for the '02 dyna transmission question is because a friend offered me a gear set out of an '02 for $200.
I'm thinking about it just because I like spare parts.
Did you happen to try any..............................never mind.............
Old Oct 6, 2013 | 05:31 PM
megawatt's Avatar
megawatt
We all know what you want to say.
I bet you are bursting at the seams to say it.
Are little bits of it forcing their way out?
You can hardly hold it back.
You grit your teeth, and bite your tongue and still it is pushing hard to come out.
Soon, it will be pounding around the inside of your head trying to find a way out.
Old Oct 6, 2013 | 05:36 PM
traildog's Avatar
traildog
Sea frikin FOAM?
Old Oct 6, 2013 | 05:37 PM
megawatt's Avatar
megawatt
Sea frikin FOAM?
Yep.
Resistance is futile.
Old Oct 6, 2013 | 06:57 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Sea frikin FOAM?
Musta been hard as hell holding that in!!
Old Oct 6, 2013 | 07:02 PM
Tee&Vee's Avatar
Tee&Vee
Default it's a f*kn sickness
I am in the same 12-step program as well because hoarding HD parts is the therapy for its own symptoms.
ahahahahahaha
Old Oct 7, 2013 | 11:25 PM
cowboy 51's Avatar
cowboy 51
ahahahahahaha
1+ agreed
Old Oct 29, 2013 | 06:54 PM
texashillcountry
Dirt don't hurt
Lately when I shift into 1st gear for the first time after I start the bike it makes a ratcheting sound instead of the solid thunk it used to.
Is that a shifter paw going out?
Will the guts from an '02 Dyna 5 speed fit into my '95 Heritage?
Fixed it.
Turns out one end of the shift rod was loose.
Old Oct 29, 2013 | 06:59 PM
traildog's Avatar
traildog
My shift rod came loose once......I used.......uh.........never mind...........
Old Oct 29, 2013 | 07:07 PM
Kushman's Avatar
Kushman
ahahahahahaha
Hope my OL does not hear about that one I'll be screwed, already lost my ebay privileges at least on the one account
