Transmission question
Old Oct 5, 2013 | 08:10 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Default Transmission question
Lately when I shift into 1st gear for the first time after I start the bike it makes a ratcheting sound instead of the solid thunk it used to.
Is that a shifter paw going out?
Will the guts from an '02 Dyna 5 speed fit into my '95 Heritage?
Old Oct 5, 2013 | 11:23 AM
megawatt's Avatar
megawatt
I'm thinkin' your clutch might be just a tad sticky for that first gear selection after starting.
Old Oct 5, 2013 | 02:57 PM
Spanners39's Avatar
Spanners39
Your tranny oil is still thick from standing but it could be clutch adjustment....02 dyna internals will fit.
Old Oct 5, 2013 | 04:30 PM
traildog's Avatar
traildog
Prolly just needs a good cleaning. :-D
Old Oct 5, 2013 | 04:36 PM
Prot's Avatar
Prot
With seafoam
Old Oct 5, 2013 | 04:57 PM
Spanners39's Avatar
Spanners39
Originally Posted by Prot
With seafoam
Old Oct 5, 2013 | 05:52 PM
Uncle G.'s Avatar
Uncle G.
Mine has done that for 20 years if:
The idle speed is too fast (not warmed up enough).
The bike has sat too long (clutch dragging-not releasing when lever is first pulled in).
Doesn't seem to have damaged anything yet.
Old Oct 5, 2013 | 06:00 PM
texashillcountry
Dirt don't hurt
Thank y'all for the info.
I guess I won't worry about it then.
Old Oct 5, 2013 | 06:05 PM
Uncle G.'s Avatar
Uncle G.
Mine will also do that if the first shift is a "half-hearted" stab at the lever. You need to make that first shift like you mean it.
Old Oct 5, 2013 | 06:50 PM
texashillcountry
Dirt don't hurt
The reason for the '02 dyna transmission question is because a friend offered me a gear set out of an '02 for $200.
I'm thinking about it just because I like spare parts.
