W6 cam over ev27
Old Nov 16, 2013 | 05:34 AM
spanky02's Avatar
spanky02
Default W6 cam over ev27
Is anyone running the woods w6 cam? I wanna do a cam this winter and was thinking about the w6. Am I wrong or are the ev27 and w6 similar?
Old Nov 16, 2013 | 03:36 PM
Jasper86's Avatar
Jasper86
need lots more info.
bike? compression? 1up/2up? desired power band?
I had a W6 (and a 6H, and a W8, but thats all beside the point), but the end result is going to be dependent on what else you do.
Old Nov 16, 2013 | 04:08 PM
RHillbilly's Avatar
RHillbilly
I like woods cams i was looking at the w7 call Bob Woods he can answer your questions
Old Nov 17, 2013 | 08:23 AM
1997bagger's Avatar
1997bagger
Can't go wrong with a W6 or EV27, Woods cams might be a little more aggressive which is good but some people pull them out because they can clatter. Have to have sound lifters, good oil pressure to the lifters and setting the push rods deeper help cushion the steep lobes but the Woods cams are lights out, I have a W6H and can't detect any valve train noise.
Jasper is trying to get some info to help, big bike? light bike? deep rpm's? do you want power low? riding style? 2 up? 1 up? this stuff makes a difference for recommendations. We will have you with a W9 @ 11.5-1 and make frequent underware changes if you let us decide.
Old Nov 17, 2013 | 08:49 AM
johnjzjz's Avatar
johnjzjz
in my opinion they are almost exact - except one uses the same intake duration as the exhaust = 240* - woods - W6 -- the Andrews 27 cam splits intake 236 exhaust 240 duration -- but they are both short duration cams and they have the same LSA - 101* ( lobe seperation angle in degrees )
so a small amount of compression increase gets it going in the normal driving range, i prefer the split duration type cams over the others as the valve sizes are not the same, and its a driving feel not a Dyno machine telling you - just my take - johnjzjz
emperor wurm
Mar 10, 2017 04:41 PM
VTwinPulse
Exhaust System Topics
17
Mar 15, 2010 05:27 PM
FXWGG
Apr 17, 2008 11:46 PM
user 78082023840
Feb 15, 2007 12:17 AM
HDF Tech
Engine Mechanical Topics
Jun 25, 2005 12:59 AM
