compensator nut !!!
Old Nov 26, 2013 | 02:31 PM
Ken Oaff's Avatar
Ken Oaff
Originally Posted by machinehed
BUT if you need to remove the clutch nut , it is a left hand thread and is removed in a clockwise way !
except on an iron head sportster its a right hand thread which confused the hell out of me until I realised hd have no consistency whatsoever
Old Nov 26, 2013 | 04:59 PM
machinehed's Avatar
machinehed
Default Pics.
Originally Posted by chuckw2
did you happen to take a pic of the lock bar in use? I'd like to see how that works, I get the idea just like to see it in action...
I saw some pics. but cant remember if they were from this site or utube.
The bar can only fit one way to tighten and only one way to loosen.
You will see how it should fit when you remove the primary cover and see the sprockets.
Old Nov 26, 2013 | 09:35 PM
Jim Kraft's Avatar
Jim Kraft
I used an old plastic handled screw driver handle to lock the sprockets and an impact on the nut. Both on and off. My son uses the impact on his without locktite and has never had it come loose yet. I do use a couple of drops of blue just for good measure, but never have used red.
Old Nov 27, 2013 | 03:31 PM
chuckw2's Avatar
chuckw2
seems like putting the bar up against the teeth and hitting them with that kind of pressure couldn't be good either...I used the screwdriver handle method but obviously the bar works without breaking teeth or it would have been mentioned somewhere.
Old Nov 29, 2013 | 04:10 PM
machinehed's Avatar
machinehed
Default Teeth.
Understand the consirn but the sprocket teeth are much harder than the mild steel bar stock used to make the tool . The stress is also taken by the primary chain as you apply tourque to the nut . This helps to prevent any shock damage to the sprocket teeth as the tourque is applied gradually. The lock bar ends must be rounded on a grinder to fit into the sprocket teeth as much as possible. I found no marks at all on the sprocket teeth after using a home made lock bar of standard mild steel stock.
Old Dec 1, 2013 | 11:44 PM
timsmcm's Avatar
timsmcm
If you use an impact wrench you take the chance of the magnets breaking off in pieces. Magnets fracture very easily. In all my years of doing this i have had to buy several new rotors for customers. I no longer use an impact.
Old Dec 2, 2013 | 04:50 PM
machinehed's Avatar
machinehed
Default Impacts ... bad !
Ditto timsmcm... rotor magnets are very fragile and will crack easily.
The effects of an air driven tourque unit will also put some nasty shock loads on the expensive parts inside the crankcase.
Stay safe and use the lock bar as desrcibed.
deucegray
13
Jan 31, 2022 12:37 PM
V_twins
Shovelhead
Aug 24, 2013 04:59 PM
Gully
Shovelhead
28
Feb 3, 2012 12:15 PM
sportncruise
Jul 23, 2008 10:25 PM
Pidgin
Apr 21, 2008 01:38 PM
