How do a I adjust the fork adjuster nut
Old Nov 23, 2013 | 12:32 AM
misfitJason's Avatar
misfitJason
Default How do a I adjust the fork adjuster nut
Or the fall away procedure. The manuals says to just adjust it with the top tree on by loosening the pinch bolts of the trees. Is there a special tool to do it? Wa there a torque spec for it when I was assembling the front end. Do I need to take the top tree back off. Oh yeah is a standard softail wideglide and not the one with a nacelle
Old Nov 23, 2013 | 01:02 AM
Spanners39's Avatar
Spanners39
There probably is a special tool but you can use a C Spanner...no torque spec, you adjust to fall away or until there is no slack fore and aft as you pull on the fork legs and it doesn't feel notchy....you don't need to take the top tree off.
Old Nov 23, 2013 | 09:49 AM
misfitJason
Thank you spanners
MartinSporti
2014-2024 Touring Models
Mar 13, 2015 07:24 AM
GlobeWarmer
Aug 12, 2013 02:02 PM
gaillarry
May 17, 2009 09:20 PM
Booey424
Mar 27, 2008 04:34 PM
mojo
Jun 22, 2006 05:53 PM
