Storing these beasts.
Old Dec 2, 2013 | 12:22 PM
MJHJEA's Avatar
MJHJEA
dust....my first thought too. If he forces his friend to make good on winning his auction, he'll end up rubbing off all the paint on his only bike.
Tee&Vee's Avatar
Tee&Vee
Originally Posted by traildog
Add some stabilizer, take a ride to get it through the carb, turn off the petcock, and let her sit. I also use a trickle charger.
I started my last bike every now and then. One time it puked its tranny fluid.
I already added stabilizer to my current ride, but, the temps are going to stay in the 50's, so. I'll have to do it again.
just do this and she'll fire up first 'kick'.
lol
Old Dec 2, 2013 | 12:54 PM
traildog's Avatar
traildog
Originally Posted by falconbrother
If I store mine for a whole winter I drain everything. I once stored a Yamaha SECA for the winter with gas in the tank. It rusted really bad. So, I ride my bike all year and it's not an issue.
It rusted WITH gas in the tank? Hmmmm. I would have thought the opposite.
Originally Posted by bluharley
And she's always ready for a good cleaning. After a week of dust, she really needs it !
WHY YOU !@#$%^&)(*&%^$#@!!@@#*#&@$^!%~$$!&
Friend? WHY YOU!@$*&)*($%^^@!@#!#&#$^&($&^!%
Old Dec 2, 2013 | 01:04 PM
Spanners39's Avatar
Spanners39
.....or you could just harden up and ride.....
Old Dec 2, 2013 | 01:17 PM
aaamax's Avatar
aaamax
That is exactly what the local rats say to me here. But damn that salt screws things up fast.
Stabilizer and full tank>run to drain carb> get off ground if cold in garage> don't start until spring.
Old Dec 2, 2013 | 01:30 PM
Hackd's Avatar
Hackd
In the twenty odd years I've owned my FLHS, I've probably done every permutation and combination as far as storing goes. Here's what I've settle on:
Fresh oil in all holes
Tires filled to correct psi
Bike washed/dried (optional if it's too cold and not too nasty with bugs)
Fresh gas, tank topped off
Battery out and on Tender
Bike up on stand and under breathable cover
I've stored it in both heated and unheated spaces. Doesn't seem to matter.
Old Dec 2, 2013 | 01:54 PM
Harley_Dude's Avatar
Harley_Dude
I've already topped off the tank with stabil and she's plugged in to the battery tender.
You're done. See you in the spring.
Old Dec 2, 2013 | 05:40 PM
machinehed's Avatar
machinehed
Default winter storage.
Ditto Hackd... We Canadians are used to this machine storage thing but i have noticed a few changes lately .
The winters are becoming warmer with more humidity and the pump gas we all pay so much more for lasts approx. 90 days before it starts going bad.
The price of gas stabiliser has doubled as a result.
With this being said ... i suggest a good shot of fogging or standard oil into the cylinders and rotate the motor while injecting the oil into the spark plug holes. If possible you can do this twice over the winter. This will keep the cylinders healthy.
Its very important to keep the fuel system clean by preventing rust in the fuel tank and sour gas fouling the carb.
Keep the tank ok by filling it to full with high test gas and gas stabiliser . An occastional shot of methel hydrate will insure that humidity will not cause any water to accumulate. Be sure to run this mixture through the carb. by taking it for a ride before putting her to bed for the winter.
Old Dec 2, 2013 | 06:57 PM
Hackd's Avatar
Hackd
I did that the first couple of years. Don't do it now. I suppose if it was going to be stored for longer than the five months it is, I'd consider doing it again.
Used to be the regular thing when I winterized the engine in my boat. Get a can of engine fog and spray it in the carb until it died. Then pull each plug and put a shot down the hole.
Like I posted, I've done it just about every way. One year I did NOTHING but put it on the stand and cover it up. Dirty oil and half tank of gas. Damn thing started right up the following spring like I'd been riding it every day.
I sometimes find, that the better I treat things, the worse they treat me.
Old Dec 2, 2013 | 07:54 PM
bagga's Avatar
bagga
all i do is take the battery out and drain the oil. the check ball leaks some and the bottom end would get oil in it so i drain it. fresh oil in spring and put the battery in it and it's ready to go. i didn't even wash it but i did cover it up this year, the last few years i didn't.
