Solo Seat installation 1990 FLHTP
Old Dec 22, 2013 | 01:33 PM
dodursley's Avatar
dodursley
4th Gear
Default Solo Seat installation 1990 FLHTP
ust installed a solo seat on my FLHTP using a XL Kong as a spring. As I am UK based I had to make and mend for most of the components due to the shipping costs.
I did buy a late seat from US and I had a T bar probably off a FXR, had it in the garage for years.
I mounted the Kong on the T bar with a 1" long 1 1/2" diameter aluminium spacer. The bottom I put in a small short tin can with a 1" hole drilled in it, same size as the hole in the bottom of the Kong, The tin is the right diameter (~3") to just contain the Kong. I used a CV joint bellows to cover the Kong so it looks a bit more 'mechanical' used worm drive clips top and bottom to clamp it to spacer and can. I machined a platform to sit on the frame cross member to allow the Kong (in the can) to sit flat and added a spigot that fits through the Kong bottom hole, keeps it in position but allows the T bar & Kong to be hinged up easily. The seat fits on the T bar in the normal manner.
The frame cover I made from 1mm aluminium sheet in 3 pieces tail bump, centre and nose riveted together. Covered the sheet in a thin layer of camping foam and then vinyl cover to make it look like the proper plastic cover. made the front hinge bracket out of mild steel so I could position the hinge and hence seat to suit me. I think it is a bit forward of the standard hinge location (1/2"?).
Now assembled and waiting for the rain to stop!
Attached Thumbnails Solo Seat installation 1990 FLHTP-slide1.jpg   Solo Seat installation 1990 FLHTP-slide2.jpg   Solo Seat installation 1990 FLHTP-slide3.jpg
Old Dec 22, 2013 | 01:53 PM
Ken Oaff's Avatar
Ken Oaff
this sounds like a lot of work, I just used 2 3" bicycle seat springs at the rear under the t bar
these aligned with holes already in the frame cross member
seat ended up about 1/2" above frame rails and has enough movement to iron out most bumbs
Old Dec 22, 2013 | 02:14 PM
Kees's Avatar
Kees
Good effort..... I used the same seat on my roadking...but I didn't use springs or shocks but just bolted at the rear. I made my own t bar brackets so like you I could position it where I wanted it...it feels real nice.
Old Dec 23, 2013 | 06:54 AM
aaamax's Avatar
aaamax
Xlnt with the pics. Solo seat is my ideal as well, springs and all.
Have fun waiting for the sun.
cheers.
Old Dec 23, 2013 | 08:32 AM
Beemervet's Avatar
Beemervet
Nice work.......... but now you will have dogs chasing after that Kong.
vinnib
Feb 1, 2016 07:51 PM
Kevin883
Jul 4, 2012 06:51 AM
rayflo
Apr 14, 2012 02:15 PM
boazbird74fxe
Shovelhead
Oct 10, 2011 12:47 AM
LEO1969
Ironhead
Nov 1, 2007 10:33 AM
