Heads aligned with intake?
Old Jan 6, 2014 | 12:44 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Spanners39
On a twin cam you can't get the heads out of line and even if you decked the heads it doesn't change the interface at all. I would suggest you might be over tightening the bolts.
Does this apply to EVO's as well as Twinkies??
Old Jan 6, 2014 | 01:28 AM
Spanners39's Avatar
Spanners39
It does but the dude is a heretic like me
With the S&S manifolds I do believe there are two different thicknesses of manifold rubber....I will check with my S&S guys tomorrow but I had a real hard time getting an S&S motor to work once and it was the manifold seals...watch this space...
Old Jan 6, 2014 | 08:19 AM
aces&8s's Avatar
aces&8s
Iv talked to a few mechanics & S&S about the seals and get different opinions. S&S said to tighten bolts to 15 lbs. S&S told me on the seals," use their seal" and then said," if, and ,but, then". So Now I am confused. Seems like it depends who you talk to.
Old Jan 6, 2014 | 08:40 AM
texashillcountry
Dirt don't hurt
I don't thing heretic is the right word to describe you.
Please pick from the following
balmy, barmy, bats, batty, bonkers, buggy, cracked, crackers, daft, dotty, fruity, haywire, kooky, kookie, loco, loony, loopy, nuts, nutty, round the bend, around the bend, wacky, whacky
Old Jan 6, 2014 | 09:26 AM
aces&8s's Avatar
aces&8s
Usually depends on which brand of tequila is at hand.
Old Jan 6, 2014 | 11:00 AM
busterman2's Avatar
busterman2
I had a leak on my 1991 FLT after reinstalling manifold, but the leak was between carb and manifold. I got the manifold installed at wrong angle and then when you bolt carb air filer or what ever mounts you have to heads, it pulls carb away from manifold and caused bad leak. I would mount manifold loosely, than install carb and bolt to heads firmly. Than tighened up manifold at heads with carb holding it at the correct angle.
Old Jan 6, 2014 | 01:53 PM
aces&8s's Avatar
aces&8s
Thanks, that is generally how I do it also. I leave everything a little loose then get a good alignment on everything before snugging everything up a little at time so everything aligns well.
Old Jan 6, 2014 | 02:14 PM
Spanners39's Avatar
Spanners39
Manifold should still move with the bolts tightened, its only sitting in rubber...that's how I aligned Kees's manifold, tightened it all up with it aligned by "eyecrometer" and pulled it into its final possie once the carby was in the manifold.
Old Jan 6, 2014 | 02:29 PM
aces&8s's Avatar
aces&8s
Thanks span, sounds like the ticket. In that case I would think to use the thicker HD seals as long as they fit snugly.
Old Jan 6, 2014 | 05:59 PM
Spanners39's Avatar
Spanners39
The S&S manifolds use a thin rubber seal for the Super G's and the stock H-D seals for the E series so my man at the Indy informs me.....so you probably should be using stock ones.
