Heads aligned with intake?
Old Jan 6, 2014 | 06:39 PM
aces&8s's Avatar
aces&8s
Originally Posted by Spanners39
The S&S manifolds use a thin rubber seal for the Super G's and the stock H-D seals for the E series so my man at the Indy informs me.....so you probably should be using stock ones.
Thanks Span that's good to know. That and proper assembly will get me going.
Thanks for everyone's input.
Old Jan 7, 2014 | 08:17 AM
LowriderHarold's Avatar
LowriderHarold
Default yep
Heres a link to S&S: One is for stock port size the other is for S&S port size. Ran into the same thing when I replaced mine , earlier in 2013. hth
http://www.sscycle.com/product/cart....&customListIds=
Ride safe,
Harold
Old Jan 7, 2014 | 08:36 AM
aces&8s's Avatar
aces&8s
Thanks Harold S&S sent seals that are the same circumference as stock HD except the S&S are good bit thinner. I believe The stock HD will give me a better seal.
Old Jan 9, 2014 | 04:32 PM
FlamedFXR's Avatar
FlamedFXR
Ditto on HD seals for S&S manifold....been there done that.
Old Jan 9, 2014 | 07:03 PM
aces&8s's Avatar
aces&8s
Thanks Flamed appreciate it.
pococj
Shovelhead
Apr 27, 2026 11:01 PM
tootal
Engine Mechanical Topics
40
Aug 5, 2017 10:23 AM
topdong1
Ironhead
17
Apr 17, 2008 04:01 PM
Reffixer
Exhaust System Topics
Nov 2, 2005 02:38 PM
HDF Tech
Jul 3, 2005 01:11 AM
