Fast idle solenoid
Old Jan 29, 2014 | 07:24 PM
Dgaroutte's Avatar
Dgaroutte
Default Fast idle solenoid
I have a 1997 Ultra Classic with EFI and am trying to finish it up, but have encountered numerous electrical problems. The bike sat outside on a jack wrapped up in about three tarps for 7+ years. My question is "does the fast idle solenoid engage when the ignition and run button are turned on?" When the switch is turned on, the fast idle engages and the fuel pump primes. The fast idle solenoid also cycles when the run button is turned off. All of the lights and gauges are working, but just want to double check before I put the tank back on for the third, maybe fourth time. I have installed new switches, new temperature sensor and a programmable ignition. I have also checked every ground on the bike and cleaned all of the connectors twice. Thanks in advance!
Old Jan 29, 2014 | 07:48 PM
Dr.Hess's Avatar
Dr.Hess
I don't have an answer for you, but from my experience with EFI in general, I think you are OK. Put it together and go for a ride around your island.
Old Jan 30, 2014 | 04:29 PM
1997bagger's Avatar
1997bagger
The fast idle solenoid or stepper motor will move at ignition on and reset to needed position and back off according to the signal from the ETS through the ECM, as long as it is moving you are ok
Old Jan 30, 2014 | 05:01 PM
Dgaroutte's Avatar
Dgaroutte
Thanks for the info. I hope to finish everything tonight and get it off of the jack that its been sitting on for the past 7 years. I'll let you know what happens.
Teroy
Sep 29, 2015 11:22 AM
Sketz
Feb 19, 2009 07:40 PM
thehueg
Aug 7, 2008 03:22 PM
johnica
Jun 18, 2008 06:34 PM
joerose
May 1, 2008 09:56 PM
