92 EG seat
Old Feb 11, 2014 | 11:49 PM
Scooby6611's Avatar
Scooby6611
Default 92 EG seat
Will a 09 EG seat work with my 92 EG?
Old Feb 12, 2014 | 12:01 AM
kirbyblue's Avatar
kirbyblue
no. seats up to 1996 fit. If I remember. I put a '96 on mine
Old Feb 12, 2014 | 04:31 AM
HGM's Avatar
HGM
Cant say, specifically, about an '09. However, my '95 has sported an '84 and curently an '05 with very little modifications.. So I would shy fron "no", but there is only one way to find out for sure.. I was recently reminded that you could easily cut or modify the seat pan as needed, depending on what your motive is..
Old Feb 12, 2014 | 08:03 AM
rapid49's Avatar
rapid49
I have a Lepera off of an 05 that I modified to fit my 95. I cut the tab off of the front and made a bracket out of flat bar to catch the tab on the bike. Works great ,no problems.
Old Feb 12, 2014 | 08:15 AM
Scooby6611's Avatar
Scooby6611
Could you post a pic of the finished product?
Old Feb 12, 2014 | 08:32 AM
grbrown's Avatar
grbrown
I have an '09 tank on my 1990 Glide. While Harley has successfully made the later tanks look very similar to earlier ones, it is actually much longer, so projects further rearwards on the frame. The mounting for the nose of the seat is also different. So while you may be able to make the seat mount on your bike, the nose of the seat won't fit up to your tank, also it will not overlap it as much. I would guess an earlier seat, say up to '07 would be more suitable.
Old Feb 12, 2014 | 03:36 PM
rapid49's Avatar
rapid49
Yea Scooby , as soon as I can get in the shop where the seat is I'll get you a pic.
Old Feb 12, 2014 | 04:30 PM
rapid49's Avatar
rapid49
this is how I made the seat work. 1/8x 3/4 flat bar and 3/16 rivets. Set your drill bit so that you don't drill in the seat cover.I had to do this twice . I mis measured the first time and had to move it back a little. Quick fix works good.
GibsonSG05
Nov 23, 2012 10:04 PM
Dans03RKC
Aug 20, 2012 04:07 PM
convincor
Sep 14, 2010 02:55 PM
kens03
Feb 10, 2010 04:58 PM
Smokedawg
General Topics/Tech Tips
Aug 2, 2007 08:13 PM
