Fuel valve
Old Feb 26, 2014 | 11:39 AM
Springer Boy's Avatar
Springer Boy
Originally Posted by JohnnyC
Those $20/$40 petcocks may work for some but they are junk and will leak because they are not designed with quality in mind. I can say this after 2 different Drag Specialty and one other even more expensive ($60) el cheapos. Time wasted. Much gas spilled.
I now have a $129 Pingel and it's the quaility you want too.
The Pingel has a nylon block that turns to the openings for main and reserve. They are very reliable and will outlast 3 cheap ones.
The cheap ones use a rubber grommet with holes in it. The rubber tends to turn soft with today's gas and melt then leak right out the front of the valve.
This is good advice, thank you. I will spend the money and order a Pingel.
Now just to decide which one! The website I looked at lists about five that will fit my bike, and I honestly cannot tell the difference between them. Seems that brass with chrome finish is the most desirable (Costs the most)
Cheers
KC
Old Feb 26, 2014 | 12:03 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Cheers
KC
Pingle has several different designs.
The one thing you need to remember is get the non-vacuum one!!!!!!!!
x1rider
Sep 2, 2015 08:18 PM
LeFat1
Carburetor Related
Mar 3, 2014 05:06 PM
rclong211
Aug 17, 2010 07:22 PM
o3softtail
Jun 23, 2009 12:57 PM
mvinc01
Mar 14, 2007 01:38 PM
