1989 FLH, No Spark
Old Mar 10, 2014 | 01:43 PM
Delawaredave's Avatar
Delawaredave
Default 1989 FLH, No Spark
1989 FLH, No Spark. Have service manual - starting to read.
Any tips or "first place to start" on diagnosing this ? Usual culprits ?
Thanks !
Old Mar 10, 2014 | 01:51 PM
Beemervet's Avatar
Beemervet
ignition module or coil
Old Mar 10, 2014 | 04:26 PM
Jasper86's Avatar
Jasper86
this
or melted cam pickup, if it gets bad enough.
any prior symptoms? or did it just die out of the blue (out of the blue would sound more like a module or more likely, coil).
Old Mar 10, 2014 | 04:29 PM
Spanners39's Avatar
Spanners39
Only a few things to check....ign pick up, coil, broken wire or module.
Substitution is the only real test.
Old Mar 10, 2014 | 06:16 PM
highbarst's Avatar
highbarst
The 2 wires at the coil one should be batt. + with key on other should be a ground that will flash while cranking eng. if both are good replace the coil .
Old Mar 11, 2014 | 11:36 AM
Delawaredave
Thanks for help and comments !!!! I'll investigate later this week and report back.
Old Jun 22, 2014 | 09:48 PM
Delawaredave
Back to work on bike - found coil. With wires on coil and key turned on, I measure 10.92 Volts on left small (primary) post, get 10.88 Volts on right.
Then took wires off coil, measured 11,300 ohms across big posts (secondary). Service manual calls for 11,250 to 13,750 ohms. So seems OK.
However measuring across small terminals (primary), first I get open circuit, then after 20 seconds or so I get 7 M ohms. This is Mega ohms ?
The spec across primary coils calls for 2.5-3.1 ohms. So this seems way out of specification, right ?
Here's picture of coil: http://postimg.org/image/ek0a2cpet/
Appreciate any thoughts. Thanks for your help !
Old Jun 22, 2014 | 10:31 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If your coil failed the test I would replace it.
Old Jun 23, 2014 | 08:13 AM
Dr.Hess's Avatar
Dr.Hess
Sounds like the primary side is open. New coil time.
Jolly_Roger
18
Jun 17, 2019 06:54 PM
roadkiller99
EVO
11
Mar 28, 2015 03:01 PM
Delawaredave
Jun 29, 2014 11:32 AM
lagunatic
Shovelhead
Jan 17, 2013 05:36 PM
alwayswrenchingmyhog
May 11, 2007 01:27 PM
