Anyone running the V&H Propipe?
Old Mar 14, 2014 | 07:22 PM
traildog's Avatar
traildog
Default Anyone running the V&H Propipe?
Looks kinda cool to me. Just curious.
Old Mar 14, 2014 | 08:19 PM
HarDlife's Avatar
HarDlife
It's on my list of choices when I do go 2-1. VnH pro pipe, Freedom performance union, or Cobra pro hp.
Would LOVE to have LSR pro stock, but a little too pricey, takes quite a while to get (built to order), and I have read they can be a little snippy when it comes to customer service. They are the best sounding pipes I have ever heard on an EVO, though!
Old Mar 14, 2014 | 10:55 PM
cowboy 51's Avatar
cowboy 51
they might be a bit loud for you, But are good pipes ,
Old Mar 15, 2014 | 05:36 AM
traildog's Avatar
traildog
That's kinda what I'm looking for, more sound. I looked at some videos, but, they really don't tell me much.......
Old Mar 15, 2014 | 07:28 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Plenty of people sell slip on mufflers.
Changing the mufflers would be my suggestion if you want something louder.
I had a set of screaming eagle slipons when I had stock pipes and they sounded pretty good.
Old Mar 15, 2014 | 10:53 AM
ReefRaider's Avatar
ReefRaider
I had put the PRO pipes on my 2010 Street glide. Would I use them again NO.
The baffle inside the muffler was welded together so poorly that it ended up busting in to parts which I ended up rewelding back together. The srews that bhold the billet end cap in place even with red lok tight would work their way lose. The heat shilds were to small so you can see the pipe underneath . I also had the V&H air cleaner and the Fuel pak. The fuel pak was the 1st thing to go. Total $hit. Along with the air cleaner which started coming apart also.
Old Mar 15, 2014 | 11:31 AM
Son of PMS's Avatar
Son of PMS
The Super Glide came with one. It looks OK. It sounds OK. Really sound more like a small block Chevy than a Harley. They make, or did, a quiet baffle for it if it's too loud for you. Smart Partz also make one. The stock baffle is easy to get out and modify. I drilled some holes in the end of it. Now it sounds more like a Harley but it's loud enough to become annoying after a while.
I haven't noticed any quality issues other than the rear header heat shield being 1/8" too short. If you can get it aligned perfectly it will actually cover, I've done it but I don't remember how.
I considered replacing it then I watched a youtube by some hot rod builder/instructor. He gave a pretty good explanation of the difference between a 2 into 2 and a 2 into 1. The basic advantage is in eliminating a torque dip in the upper end on the low rpm torque curve.
It's a decent pipe for the money. It's not too loud out of the box and can be made louder or quieter.
Old Mar 15, 2014 | 12:00 PM
texashillcountry
Dirt don't hurt
Do you have a link to the video you are talking about?
Old Mar 15, 2014 | 02:25 PM
traildog's Avatar
traildog
Sure wish I could have caught the Road Glide that passed when I came out of the hardware....
His pipes sounded fantastic. Low rumble........ sweet.
Old Mar 15, 2014 | 03:02 PM
HarDlife's Avatar
HarDlife
Rush products sound really good also, TD. Bonus about 2-1 for you, it would be one less pipe to polish.
