S&S Super G Jet Issue
Old Apr 3, 2014 | 06:47 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by tdewey
Well, the previous owner had the motor re-built and upped the compression to 10:1. So I think that's why the G was used.
No matter what the compression the G is too much carb for an 80" motor.
Hell S&S puts an E on their 111"
Old Apr 3, 2014 | 06:49 AM
texashillcountry
Dirt don't hurt
Wow, that sucks. I'm keeping the pipes ,cuz I'm commited to them. They're already on the bike. Plus I'm too broke to buy another set.
If you are running straight pipes you will need something for back pressure.
I recommend a lollypop.
Old Apr 3, 2014 | 07:45 AM
little5150's Avatar
little5150
I'm just wondering, What jets are in the carb?
Old Apr 3, 2014 | 10:21 AM
Inop's Avatar
Inop
Super G carb is meant for 100 ci and above, way to big for your motor.
Old Apr 3, 2014 | 12:53 PM
tdewey's Avatar
tdewey
6th Gear
Might be an E carb. I never looked on the side of it to see. Not sure what jets are in it now. The previous owner had this motor set up like it is now. I just added the drag pipes myself. And what's a lollypop? I'll probably end up putting a set of baffles in as well.
Old Apr 3, 2014 | 12:59 PM
texashillcountry
Dirt don't hurt
Lollipop" Baffles
  • A home-made drag pipe baffle will lessen performance problems. One way to enhance performance while not cutting too far into the sound levels of Harley drag pipes is to construct a "lollipop" pipe baffle. Instead of paying up to $80 for the part, this can be made at home for about $10. Weld a 3/4-inch washer onto the end of a 1/4-inch threaded rod or bolt and wind a nut onto it. Drill a 1/4-inch hole in each pipe about 1 inch from the end, insert the lollipop into the hole from inside the pipe, and put another nut onto the protruding end of the bolt. Set the lollipop at about 90-degrees in the pipe and tighten both nuts.
Read more: http://www.ehow.com/list_7626676_har...#ixzz2xqb9xaaU
Old Apr 3, 2014 | 01:02 PM
texashillcountry
Dirt don't hurt
You might want to take a look at this
http://www.sscycle.com/tech-info/carb-quick-guide/
Old Apr 3, 2014 | 01:52 PM
little5150's Avatar
little5150
I just made some. You drill a hole about 2" from the end of the pipe on the bottom and bolt the lollipop baffles in. He is a picture, not the eye bolt.
Old Apr 3, 2014 | 02:03 PM
little5150's Avatar
little5150
How was the bike running before you put the drags on? What type of pipes where on there before the drags?
Old Apr 3, 2014 | 02:32 PM
tdewey's Avatar
tdewey
6th Gear
It was running fine. I just wanted some more sound. It had a set of super trap slip ons. And I just checked I have a super e carb not the super g. my bad guys!!!
