S&S Super G Jet Issue
Old Apr 2, 2014 | 05:56 PM
tdewey's Avatar
tdewey
6th Gear
Default S&S Super G Jet Issue
I have an 85 Tour Glide with an 80" Evo. Put inch and 3/4 drag pipes on it just recently. It has a S&S Super G carb on it. What would be the recommended main and intermediate jet change size changes?
Old Apr 2, 2014 | 06:06 PM
traildog's Avatar
traildog
Have you run it with the stock jets?
And welcome to the EVO section.......
Old Apr 2, 2014 | 07:06 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
A G is entirely too big for an 80" motor.
I suggest you go back to an E.
Old Apr 2, 2014 | 09:34 PM
johnjzjz's Avatar
johnjzjz
no jet can fix that - it will never run right and for sure it will wash the cylinders wall out of oil - jz
Old Apr 2, 2014 | 09:51 PM
billib1954's Avatar
billib1954
What they said. Carb too big. And trash the drag pipes, IMHO.
Old Apr 2, 2014 | 09:52 PM
Jasper86's Avatar
Jasper86
yea, gotta agree here.
I've got a G on my 124, wouldnt even dream of running one that big on my 80"
carbs (venturis) work on velocity. you're slowing down the incoming air BIGTIME with a venturi that big.
Old Apr 2, 2014 | 11:45 PM
little5150's Avatar
little5150
That is a big carb for an 80" but it might work with a 28 inter. and 66 main. Here is jetting recommendation out of a S&S manual. You can go to S&S web site an get this information. A good way to check if you have the right inter. jet is too go by the air mixture screw. It should be at about 1 1/2 turns out. If the engine runs best with the mixture screw turned out less than one turn, the intermediate is too large. If it is greater than 1 3/4 turns, intermediate probable too small.
Old Apr 3, 2014 | 06:23 AM
tdewey's Avatar
tdewey
6th Gear
Well, the previous owner had the motor re-built and upped the compression to 10:1. So I think that's why the G was used.
Old Apr 3, 2014 | 06:25 AM
tdewey's Avatar
tdewey
6th Gear
No I haven't. I turned the wrong screw to turn down the idle. I turned the idle enrichment screw by mistake and I can't find that "sweet spot" to which it'll even run.
Old Apr 3, 2014 | 06:27 AM
tdewey's Avatar
tdewey
6th Gear
Wow, that sucks. I'm keeping the pipes ,cuz I'm commited to them. They're already on the bike. Plus I'm too broke to buy another set.
