Oil seal replacement
Rate limiting step is the allen bolt at bottom of slider.
Go to harley dealer and buy the two allen bolts.washers now. Buy seals also.
The allen is something like a 6mm...needs to be really long.
Cut an allen and place in a socket or purchase a long allen socket.
They are tight so an impact is sometimes required.
No need to remove tube.
Raise bike, remove front wheel.
Remove the allen bolts. Fork oil will leak out/drain.
Slide the sliders off (difficult)..you will need a friend to hold bike steady.
Slide the old seals off.
Slide new seals on NOW.
While sliding the sliders on the tube STOP and tap the new seals in with a split PVC coupler.
You need to get the seal on the tube into the slider way BEFORE you bottom out the slider for the bolt.
Then continue sliding the slider in and install allen bolt.
You drained the fluid so now you need to put fluid back in...if you have air shocks then you can use the suction method using air valve and side drain bolt along with a mity vac or similar..If you do not have the air shocks then a funnel and tube will be required top side.
Hopefully your year has air shocks up front so you can bypass the fairing removal.
Regardless, the removal of the tube is not required but removal of the slider is required.
The rate limiting step is the allen bolt inside the bottom of slider..make sure to have the long allen that is inside a socket and an impact driver on standby.
Oh and one more thing..you probably already know this but, the front calipers on Harley don't bleed worth a flip the traditional way. But, reverse bleed them and it works quick and easy.
