85 Electra Glide Problem
Old Apr 24, 2014 | 06:10 PM
bagga's Avatar
bagga
Originally Posted by Chop
Would that hold back RPM's?
broken valve spring? take the top rocker cover off and look at the springs.
Old Apr 24, 2014 | 06:43 PM
johnjzjz's Avatar
johnjzjz
you said you changed the oil i think i read - if so do you know for sure you have an evo oil filter and not a twinkie filter on it - harley morons think the 2 are the same at my local dealer -- jz
Old Apr 24, 2014 | 08:10 PM
Chop's Avatar
Chop
Changed oil and filter after it acted up. No difference with new oil, filter,and plugs. 4,000rpm max. Lot of things this could be. No problems until crank up this year. 10,000 miles on topend. New rings, valves, valve guides, springs and retainers, lifters new also.
Old Apr 24, 2014 | 08:41 PM
johnjzjz's Avatar
johnjzjz
you will have to check the block vent the 85 if thats the bike it needs to be open to the air -
if its clear and air is freely blowing out when running -
you might have to remove the cam cover to check the breather valve if its still the plastic one it could have broken
Old Apr 25, 2014 | 04:33 AM
Chop's Avatar
Chop
Would that cause the rpm problem? Hope not valve spring. They only have 10,000 on them.
Old Apr 25, 2014 | 04:37 AM
Chop's Avatar
Chop
Would that cause maybe the lifters to float (rpm problem). Strange how this just all of a sudden happen.
Old Apr 25, 2014 | 09:15 PM
Chop's Avatar
Chop
Thx for the replies........
Let U know when I get time off work, what I find
Chop
Old Jul 17, 2014 | 07:58 AM
Chop's Avatar
Chop
With all the experienced Rider's on here, I really think someone would have addressed my rpm problem in my prior posted better than it was handled. bagga u were bond and determined it had a broken valve spring. Wrong.
Had operation on knee and been laid up for quite awhile. Finally got to look at 85 Electra Glide yesterday and found problem. It has an Crane Single fire race ignition on it and the rev limiter adjustment has a scorched area on it. Thats the problem on the rpm's. The oil gurgling went away. Checking today into getting a new one or another brand for it. WAS not impressed with the Advices I got on here about the RPM problem.
I know I didn't post it as a rpm problem, but it was also a (major part of my problems) in my post. Might should of made new post for rpm problem
Old Jul 17, 2014 | 08:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
A rude and snotty post. Talk about unappreciative..
These guys tried to help you figure out you problem.
Next time just take the bike to a mechanic, you don`t need any help from here.
Old Jul 17, 2014 | 08:16 AM
traildog's Avatar
traildog
Geeze o pete man "bond and determined" after ONE suggestion..........????
